Looking for Pics of this installed
6 replies to this topic
#1 KennyP ONLINE
  • 41,004 Thanks
  • 47,162 posts
Posted November 22, 2011 - 08:09 AM
While researching my dump trailer build, I came across this in JD Parts:
I have looked around, but cannot find a pic of this installed on a wagon. It looks like a simple way to exchange the jack for a cylinder and make a full hyd. dump. The exploded views don't show exactly how this is installed in the wagon, that is what I am trying to find. If someone can offer up some info on it, I would be very happy.
#2 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted November 26, 2011 - 03:43 PM
the rods number 1 are pivot points and also the rod that is on the triangle plates. the rod close to the hydraulic cylinder attaches to the frame of the trailer as does the rod on the triangle plates the other to the tilt box
should work
looks like you are having fun figuring it out
good luck you will have a good dump trailer
good idea
#3 KennyP ONLINE
  • 41,004 Thanks
  • 47,162 posts
Posted November 26, 2011 - 06:01 PM
Okay. If I have this figured right, 1A and 1B go where I have them marked below. The Blue pin attaches into the bed. Is that right?
2306-221Wagon.jpg Posted Image
If so, do you by chance have a dimension between 1A & 1B mounting holes? Also, between 1B & the Blue rod?
#4 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted November 26, 2011 - 09:24 PM
check out this web site www.DumpBeds.com - The only resource for do-it-yourself dumpbed plans
look at the pictures, it should help you.
  • Texas Deere and Horse and KennyP have said thanks
#5 KennyP ONLINE
  • 41,004 Thanks
  • 47,162 posts
Posted November 27, 2011 - 08:30 AM
I bookmarked your link. Should be able to make something out of that info. I would like to scale the scissor lift down for GT purposes and make the plans available for the members here. That will take some input from the hydraulics guru's as far as cylinder specs. I know a lot of people would like to have a Hyd. dump for their trailers. May take a while to do this.
#6 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted November 27, 2011 - 01:22 PM
one should be able to use a cable wench (manual or electric)
#7 KennyP ONLINE
  • 41,004 Thanks
  • 47,162 posts
Posted November 27, 2011 - 01:45 PM
Got one of those. Time for a hyd. setup.
