Snowthrower Missing Parts
9 replies to this topic
#1 Laseman OFFLINE
Laseman
  • 20 posts
Posted November 21, 2011 - 04:16 PM
Hope you have som answers to my questions of parts for Jacobsen GT42 inch Snow Thrower 59794 for Jacobsen GT16 (Homelite, Ford)
I have to weld Liftarm and find "balance spring" for Snowthrower
1.
what is the purpose of nr1 (45) "balance spring" ?
is it for push up or push down or what....
2.
Where on GT16 will this Fork nr2 on Liftarm be placed ?
Should it be placed on 2A or 2B or what ?
3.
If Liftarm shold be placed on 2A that is static, how can the Snowthrower be lifted up and down then ?
4.
spring is missing for idler arm PTO
should the spring be placed at hole A and B ?
Thankful for answer
#2 ford boy OFFLINE
ford boy
  • 21 Thanks
  • 87 posts
Posted November 24, 2011 - 12:00 PM
(1) all the two springs do is hold the blower houseing from falling forward and it acts sort of like a trip action , (2) if you look closely at the lift arm you will see that theres a latch on one end and the other end bolts to the blower houseing , the lift arm latchs onto 2A , (3) the lift arm is just ment to be attached and pivot on 2A , up front on the lift carrage which is on the tractor theres a round rod , its right below the front axle , then the lift arm sits on that rod and when the lift carrage is lifted the rod is in turn lifted and then blower arm is in turn lifted , (4) i would attach the spring to A and the attach the other end of the spring to the left side of the frame , you might have to drill a small hole in the frame but i would think it would work fine , tech speaking mode off:bigrofl:
  • MH81 and Doug G have said thanks
#3 Laseman OFFLINE
Laseman
  • 20 posts
Posted November 25, 2011 - 04:49 PM
Thanks for answer
(1) all the two springs.... OK
(2) if you look closely at..... OK
(3) the lift arm is just ment to...... Maybee OK, see below
(4) i would attach the spring to..... OK,
Can you please take a picture of how your PTO looks like with original spring around pivot arm (about 4)
Best regards / Laseman
Edited by Laseman, November 27, 2011 - 03:24 PM.
#4 Laseman OFFLINE
Laseman
  • 20 posts
Posted November 27, 2011 - 03:29 PM
Here is my Liftarm, nearly ready (home construction)
Lift arm latch 3A is connected to 2A rod under tractor
When huydralic is lifting up "Mowing Deck Carriage" 3B it also make front of "Liftarm" 3C to lift Snow Thrower
Is this correct ?
Edited by Laseman, November 27, 2011 - 03:37 PM.
#5 ford boy OFFLINE
ford boy
  • 21 Thanks
  • 87 posts
Posted November 27, 2011 - 04:09 PM
:thumbs:yup thats the factory way in is ment to attach , the arm looks nicely done
#6 Laseman OFFLINE
Laseman
  • 20 posts
Posted November 28, 2011 - 04:41 PM
Hi "Ford boy"
Do you mean around "C" in this picture ?
spring_pulley_IMG_1362C
When you wrote "....attach the other end of the spring to the left side of the frame"
I am not shore if you mean Left side of tractor or Left side in that picture !
Can you please take a picture of how your PTO looks like with original spring around pivot arm.
Best regards
#7 ford boy OFFLINE
ford boy
  • 21 Thanks
  • 87 posts
Posted November 29, 2011 - 01:49 PM
sorry for the late reply , unfortunately my snow blower pto setup is missing some parts too , but i managed to find a thread on another forum with a photo of where the spring should mount on the frame its the 3rd photo down from the top , also that photo was taken from the left side of the tractor as you sit on the tractor , the other end of the spring mounts in hole A in your photo , granted this pto setup is a little different then yours and mine but i thought it might show you how the spring go's , FORD LGT 42" Single & Dual stage Snow Thrower info - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information sorry i can't help more right now , but i will look around and see if i can find any other pictures for you
#8 Laseman OFFLINE
Laseman
  • 20 posts
Posted November 29, 2011 - 04:01 PM
Hi
Thanks so much for that link, very interesting.
I think that can help me.
:smile1:
best regards
#9 LGT100 OFFLINE
LGT100
  • 2 posts
Posted January 10, 2012 - 03:02 PM
I just purchased a snowblower online and then discovered that the lift arm is missing. Would you consider sending me the dimentions or drawing for the one you made. I will try to have one made localy.
Thanks for your help.
#10 mjodrey OFFLINE
Posted January 24, 2012 - 10:28 AM
LGT100,welcome to the forum.Glad to have you with us.
