Blown Hydraulic hose
6 replies to this topic
#1 projectnut OFFLINE
projectnut
  • 25 Thanks
  • 55 posts
Posted November 18, 2011 - 11:39 AM
This morning I went out to start my Case 224 and got a messy surprise. It started fine and I let it warm up a few seconds then put it into reverse. There was a hesitation then the pump made a slight whine. I immediatly shut it off, put the axle in neutral, and pushed it out of the garage. I was shocked to find the short hose to the cooler had a hole blown in it.
Earlier this year I replaced both hoses to the cooler becase they seemed a little soft and mushy. The hoses I replaced were 3/4" Dayco heater hose so I used the same thing. I'm thinking the previous owner may have had problems somewhere along the way and installed these hoses. I don't know if letting the machine warm up would have avoided the problem or the hose I used just wasn't up to the task.
What does everyone else use for these hoses, and how long should I let the machine warm up in 35* F weather?
Thanks projectnut
#2 ducky OFFLINE
  • 1,961 Thanks
  • 4,085 posts
Posted November 18, 2011 - 11:45 AM
The hose you are using is not correct. Heater hose is not compatible with oil and will fail in short order.
You need to use a hose that is compatible with the fluid in your system.
  • bhts said thank you
#3 bhts OFFLINE
bhts
  • 1,452 Thanks
  • 2,149 posts
Posted November 18, 2011 - 11:54 AM
:ditto:
#4 olcowhand OFFLINE
  • 38,038 Thanks
  • 30,448 posts
Posted November 18, 2011 - 12:09 PM
:ditto:
:ditto::ditto:
#5 projectnut OFFLINE
projectnut
  • 25 Thanks
  • 55 posts
Posted November 18, 2011 - 01:44 PM
Thanks everyone. Now I know why the hoses I took off looked so new yet felt so mushy. I just got back from the local Fleet Farm. They have hose that looks identical to the hose I used but is clearly marked HYDRAULIC. Hopefully this afternoon I can get the mess cleaned up and some new hoses installed.
#6 ducky OFFLINE
  • 1,961 Thanks
  • 4,085 posts
Posted November 18, 2011 - 01:45 PM
Glad we could help.
  • projectnut said thank you
#7 projectnut OFFLINE
projectnut
  • 25 Thanks
  • 55 posts
Posted November 19, 2011 - 01:26 PM
Well the beast is up and running again. It didn't take long to remove the old hoses. The new ones were a bit stiff in the cool weather so I gave them a shot of warm air with a hair dryer before slipping the ends over the tubes. I had to add 7 quarts of oil to the system which explains the big mess on the garage floor. I took it for a test drive then put it to work for a little while. It's now back in the garage until it gets called back to duty next weekend. Hopefully next time there won't be any surprises and I can get a few loads of wood hauled in a couple hours rather than a couple days.
Thanks again for all the help, projectnut
