MF7 Executive 3 point hitch
#46
ONLINE
Posted December 29, 2011 - 12:43 PM
#47
OFFLINE
Posted January 01, 2012 - 08:04 AM
OK, finally have 10 seconds to explain my statement from this AM.
What I am about to describe will require removal of the lift arm you just welded on... sorry. double check what I'm saying first.
in the pic below, if you could turn the piece labeled "This one" past the red line and to the black line, the weight would cause it to stay there. "Over Center" if you will.
[ATTACH=CONFIG]27273[/ATTACH]
After I put the power lift back on the shelf, I started playing with the linkages.
Being I had put extra holes, in all the linkages, and at different spacings, it
wasn't long before it was going over center as in Alan's picture. I did have to
drill a hole through the bracket labeled "this one", just above the "O".
That bracket isn't welded to the square shaft. Those are square holes inthe
bracket, and it slides onto the shaft.
So, at this point, when lowered, the plow goes 5" below ground level. That can be reduced with the threadall stop.
When raised, the plow is 4 1/2" above ground level. I'd like to get that a bit higher.
I'll play with it a bit more, but at least now, leisure suite larry, doesn't have to
hold that handle down anymore.
- MH81 said thank you
#48
OFFLINE
Posted January 01, 2012 - 08:44 AM
Will, I need you to tell all your relatives and neighbors your suit size. Tell them to watch for a suit at yard sales anD second hand stores that looks like that. I'd say a recreation photo is in order when your done.
#49
OFFLINE
Posted January 01, 2012 - 08:54 AM
Wake up, make coffee, click on what's new, and ta-da... Great News.
Great minds think alike. My powder blue one is ready to go. I just need ahair cut/shave, and penny loffers.
Oh yeah, might have to open up the seams on the suit, and add some material too.
- MH81 and KennyP have said thanks
#50
ONLINE
Posted January 01, 2012 - 10:51 AM
#51
OFFLINE
#52
OFFLINE
Posted January 01, 2012 - 11:29 PM
I really like the seat.
#53
ONLINE
Posted January 02, 2012 - 06:12 AM
- IamSherwood said thank you
#54
OFFLINE
Posted January 02, 2012 - 08:15 AM
#55
OFFLINE
Posted January 03, 2012 - 07:13 AM
#56
OFFLINE
Posted January 08, 2012 - 09:42 PM
MF8E - Manuals - Garden Tractor Talk - Forums
On page 7 it shows both the 3pt, and a sleeve hitch.
In the owners manual (which I have an original of) it only shows a sleeve hitch.
On page 7, the 3pt is operated on the left side, which is linked to the deck height adjustment
handle.
Interesting.
#57
OFFLINE
Posted January 08, 2012 - 09:52 PM
#58
OFFLINE
Posted January 09, 2012 - 07:14 AM
Glad it helped. I thought the pic of the adjustment nut was neat too.
Oh yeah, it helped. Haveing both hitch options for the 8E means more
shop/tractor time.:smile1:
I still haven't been able to find any of those cast thumb nuts/knobs.
#59
OFFLINE
Posted January 09, 2012 - 07:05 PM
Will did you check hapco the deck height adjustment knob for john deere flat fenders.I'm not sure what thread you're looking for.That might be something to look into.I think they were 3/8 course.Also the rear sleeve hitch height adjustment knob.Congratulations on finishing the 3 pt.Looks good.It'll look awesome on the tractor after it's painted.Oh yeah, it helped. Haveing both hitch options for the 8E means more
#60
OFFLINE
Posted January 09, 2012 - 08:21 PM
Thanks, I'll look into that Hapco lead. I'm lookin for 1/2"NC knobs.
