snow blade rod
25 replies to this topic
#16 cp7 OFFLINE
cp7
  • 59 Thanks
  • 148 posts
Posted November 24, 2011 - 09:58 PM
So billy since the link in my earlier post was adjusted I'll try again to direct you to the file for the adapter plate.
It's a very detailed blueprint pic with all the measurements very clear.
Good luck with this one.
You'll need to go join the Yahoo Case group.
http://groups.yahoo.com/group/casegardentractors/
Then you can go to the files section and then to Attachments and Implements.
There's sub files Sleeve & 3 Point Hitch, then Sleeve Hitch, then Sleeve Hitch measurements, then Sleeve Hitch Plate.jpg.
Here's the direct link but it will only work once your a member.
http://f1.grp.yahoofs.com/v1/oPbOTvym4Z-d5tM5-ZlsOsV-htLZsnebmBQusPZuoIQOWhMmJb6lCx-Fpnx29JmUC32SGLblYazzuXSJYTyInI9s/Attachments%20and%20Implements/Sleeve%20%26%203%20Point%20Hitch/Sleeve%20Hitch/Sleeve%20Hitch%20measurements/Sleeve%20Hitch%20Plate.jpg
Actually once I signed out from Yahoo the link still took me to the file.
Let me know if it works for you.
#17 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted November 25, 2011 - 05:02 AM
Hi CP7. I cannot access either of those links. The first one gives a Safari (I'm running a Mac) "can't open address" error. The second one gives a file not found error. I am a member of a few yahoo groups and IME the access is a bit inconsistent at times.
#18 mjodrey OFFLINE
Posted November 25, 2011 - 05:16 AM
Neither can I.
#19 olcowhand OFFLINE
  • 40,374 Thanks
  • 31,177 posts
Posted November 25, 2011 - 09:22 AM
I am an owner of a couple Yahoo groups, but neither of those links still won't work for me.
#20 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 25, 2011 - 09:32 AM
I can not open either of the links. They seem to be broke. Could you post the file it self.
#21 cp7 OFFLINE
cp7
  • 59 Thanks
  • 148 posts
Posted November 25, 2011 - 09:56 AM
So are you guys seeing the same thing that I am in my post? Here's a screen shot of that post.
Both links work just fine for me and did the other day too until they were messed with.
I've seen many times where links won't work but there's never been a problem with ones that I post until this thread and this site.
Billy if your still needing the file for that adapter and can't get to the Yahoo Case group drop me a PM.
#22 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 25, 2011 - 10:00 AM
Yes, That is the same thing I see.
#23 cp7 OFFLINE
cp7
  • 59 Thanks
  • 148 posts
Posted November 25, 2011 - 10:39 AM
Thanks for letting me know Ducky.
I have very little clue about how these dang machines work and probably wouldn't understand if someone explained it but why will it work for me and no one else? The link is spelled out and if I copy and paste it to the address bar it works just fine too.
Friggin computers.
With all the forums watermarking their files and it seems to me they feel like they own the information and don't get me wrong I understand how much work it is to scan and upload files but if there's info somewhere I'm trying to just send the person to get it. I guarantee you that I wouldn't be allowed to post a pic or file with MyTractorForum.com or *****************.com stamped bigger than life across the front of it and those letters there will probably get turned into x's shortly (sorry Daniel).
Shoot didn't this site just get in trouble for posting plainly marked copy written material?
GTTalk has some awesome files also and I'll send guys here to get them from the other forums too.
#24 MH81 OFFLINE
Posted November 25, 2011 - 01:36 PM
...Both links work just fine for me and did the other day too until they were messed with....
I'm the one that "Messed" with them. They were Broken Links at that time (as I explained in my PM to you) and didn't work at the time of removal. Instead of having a thread full of "Why can't I get to this...?" posts, I decided to edit out the Broken Links and leave that in the Reason for edit area.
Sorry for any confusion I may have caused instead of avoiding.
Thanks again for continuing to try to provide the information.
#25 cp7 OFFLINE
cp7
  • 59 Thanks
  • 148 posts
Posted November 25, 2011 - 07:51 PM
Thanks for trying Alan. I didn't mean anything by the way I put that.
I did try and didn't even jump in till I thought I should try and correct some misinformation because like I said I don't even have a blade for my Case.
#26 CASENUT OFFLINE
  • 505 Thanks
Posted November 28, 2011 - 12:14 PM
Ok sorry guys, I do have a photo for you, although I don't have measurements yet, you can get the idea...weekend was real busy with the holiday, then I had 2 days to take care of tractor stuff...here is the pic...
