Repair Manual
11 replies to this topic
#1 primfolk OFFLINE
primfolk
  • 5 posts
Posted November 15, 2011 - 03:41 PM
I am looking for a repair/owners manual for a model 1-7255 Electro 12 automatic.
#2 caseguy OFFLINE
  • 1,627 Thanks
Posted November 15, 2011 - 08:37 PM
:wave: primfolk Welcome to GTTalk! I looked around a bit and could not locate the manual that you need. there are quite a few guys on here who have extensive knowledge of Wheel Horses and I'm sure that they'll be along soon. I hope that you can find it. We are glad to have you here with us. thanks for signing up!
#3 MH81 OFFLINE
Posted November 15, 2011 - 09:20 PM
I'll second the :welcome: and also add that if you have a specific question, these guys are really smart, one of them may know it off the top of their head. Also, if you have a picture, we'd love to see your Horse.
#4 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted November 16, 2011 - 05:21 AM
The WH Manuals Groups do not have the 1970 1-7255 manual but you can download the 1969 manual from Toro
https://lookup3.toro...est/request.cfm
Use 1-7245 for a model number and the word none for a serial number.
(You could order the 1-7255 here also. If that does not work use the Contact Us and give them a call using the 800 number.)
They use a different engine spec number but the same breakerless ignition, 10 amp charging system, Bendix starter, hydro transmission and ignition switch so the wiring should be the same.
The Electro 12 is the same as a Charger 12 with an electic pto clutch - hense the name.
Garry
  • ducky and MH81 have said thanks
#5 MH81 OFFLINE
Posted November 16, 2011 - 07:45 AM
Thanks Garry, knew one of you guys would have a lead.
#6 plowboy OFFLINE
plowboy
    TRACTOROLOGIST
  • 133 Thanks
  • 229 posts
Posted November 16, 2011 - 08:28 AM
welcome to GTT friend! another tip fr ya. i had a hell of a time gettn the manual for my 208-3. i was told to dwnload a 300 series manual. I did so & it covered multiple models and was very detailed @ that. had everything i needed then some....good luck & post some pics if ya get a chance.
#7 primfolk OFFLINE
primfolk
  • 5 posts
Posted November 16, 2011 - 11:55 AM
Thank you this looks like a great web site. I glad I found it.
#8 primfolk OFFLINE
primfolk
  • 5 posts
Posted November 16, 2011 - 12:06 PM
I have back tore apart,I went pull a wheel off and the axle started coming out so I stopped, that's why I needed the manuals. I have split the rear end, if any body has any tricks or no no,s it would be apreciated. Thanks for my welcome here.
#9 primfolk OFFLINE
primfolk
  • 5 posts
Posted November 16, 2011 - 12:07 PM
Thanks I will.
#10 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted November 16, 2011 - 06:12 PM
You can download the illustrated parts list from
https://lookup3.toro...fm?xCaller=Toro
Enter your 1-7255 model number and the next page has a link to the ipl's. After a page opens you can click on a small printer icon at the top left of the illustration. The page will reload to one you can print. The parts lists here are terrible. Better ones are here
Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
Type Toro in the 2nd box and the 1-7255 model number in the 3rd box. The parts that are priced are still available from any Toro dealer. Have never found a good way to print these pages.
Garry
#11 MH81 OFFLINE
Posted November 17, 2011 - 12:01 AM
The picture is printable, the parts list doesn't seem to be able to be extracted without printing a few lines at a time.
If you right click in the picture, it will allow you to save it. Then you can open it as a ".php" file. If you don't have MS Image Editor, you must use something like Gimp to open & print.
#12 primfolk OFFLINE
primfolk
  • 5 posts
Posted November 17, 2011 - 10:32 AM
Thanks guys, going to give it a try.
