John Deere 110 carb gaskets??
6 replies to this topic
#1 drhntrrmw OFFLINE
drhntrrmw
  • 3 Thanks
  • 15 posts
Posted November 14, 2011 - 07:59 PM
Where do I find the gaskets between the air cleaner and carb 90 deg. manifold and between the manifold and the carb?
Thanks,
Rob
#2 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted November 14, 2011 - 08:32 PM
You can sometimes find a good deal on Ebay. I have found an action lot of 5 and 6 gaskets of each type, for $2.00 already. Shipping was the cost of a stamp. Any small engine repair shop should have them in stock as well.
#3 Trav1s OFFLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted November 15, 2011 - 09:21 AM
I picked up the pieces I needed at the local Napa.
#4 drhntrrmw OFFLINE
drhntrrmw
  • 3 Thanks
  • 15 posts
Posted November 15, 2011 - 11:51 AM
Are the two gaskets that I am refering to a Kohler part or a John Deere part?
And do you know what the part number is?
Thanks,
Rob
#5 Trav1s OFFLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted November 15, 2011 - 12:54 PM
I went with the following info to the local Napa:
1966 JD 110
k181
Also had the engine serial number and spec number handy if needed. I don't recall if they did or not. If you had a JD part number I would expect them to be able to xref it. In my case, the local Napa owner is really knowledgeable about the Kohler K series.
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 15, 2011 - 05:08 PM
Any Kohler dealer would likely have them. Most JD dealers stock a lot of carb parts for the older tractors as well. You could get some gasket material and make your own as well.
#7 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted November 15, 2011 - 06:48 PM
Air Cleaner to carb elbow/carb elbow to carb intake #220537-kohler number / M42221-John Deere number
Carb to motor #210223-kohler number / M41814-John Deere number
