414 8 snow plow
13 replies to this topic
#1 truck21 ONLINE
truck21
  • 503 Thanks
  • 286 posts
Posted November 13, 2011 - 08:56 PM
I just picked up a wh 414 and a snow blade, the blade is a 42 inch but from another model tractor. The mounting and the lift hook right up but the angle handle will not work in both directions. If anyone has a manual on this blade or pictures of the setup I need please PM me. I would guess that most other 400 series tractors would be the same. Thanks for any help you can offer.
THANKS DON.
Edited by MH81, November 13, 2011 - 09:01 PM.
#2 MH81 OFFLINE
Posted November 13, 2011 - 09:03 PM
:welcome: to GTTalk
Don, is there a model number on the plow? That would help finding a manual for it.
BTW, I pulled your email out of your post. There are spambots that will grab it and start sending you ads for Lord knows what all. If someone has the info, you can exchange emails or etc via the Private Messaging service much safer.
  • truck21 said thank you
#3 truck21 ONLINE
truck21
  • 503 Thanks
  • 286 posts
Posted November 13, 2011 - 09:07 PM
Yes the model # 6 9622 6 serial #758080
THANKS!!!!!!!
#4 MH81 OFFLINE
Posted November 13, 2011 - 09:18 PM
I just looked at an exploded view of that plow. What is keeping it from moving both ways? Is there something obstructing the handle or is it a linkage problem?
It looks like the handle is on the LHS, is this true, and which way does the blade Not Turn?
#5 truck21 ONLINE
truck21
  • 503 Thanks
  • 286 posts
Posted November 13, 2011 - 09:52 PM
THANKS MH81
The handle on the blade is on the right side, like I said this is from a different model tractor. What is keeping it from turning to the right is it hits the foot rest. It may be that I can`t use this blade at all. Thank you for all of your help. Is their a place where I can find free manuals to download or at least view?
THANKS AGAIN DON
#6 Cessna OFFLINE
Cessna
  • 6 posts
Posted November 13, 2011 - 11:41 PM
I bought a snowplow that was not for my tractor (Workhorse 11-42) but I added wooden blocks to the rear axle to lower the A frame. This allowed me to have enough clearance.
Cessna
#7 MH81 OFFLINE
Posted November 14, 2011 - 08:00 AM
Sorry, turned in early last night.
This is a picture of the plow for a 414-8 that I found online.
It has 2 big differences that I see. 1: is the extension on the back... Don't know if it's mandatory to work with your machine, i'd guess not, and the other is the handle is bent, not straight. Looks like this is your problem.
Probably wouldn't be too hard to build a new handle. I have a friend who made his own from scratch for his 314, using heavy conduit and a bicycle brake assembly for the release. His was completely missing and he had to start from scratch.
As for the manuals, we have manuals here for some WH plows, but I was google image searching, looking for differences. Hint: when looking for pictures of your plow, leave the last "6" off the model number and put a "-" where your space is. You'll get more hits.
Edited by MH81, November 14, 2011 - 08:06 AM.
#8 GWest OFFLINE
GWest
  • 553 Thanks
  • 504 posts
Posted November 14, 2011 - 12:31 PM
THANKS!!!!!!!
The model number is 6-9622.
The 6 on the end is not used but if you subrract 5 from that 6th digit you get the model year. 6-5=1971. You will see 6, 7, 8 and 9's representing 1971, 1972, 1973 and 1974.
The 6-9622 is the blade only and required 6-4112, 6-4113 or 6-4114 completeing kit.
The later photo with the extension kit 81630 or 81640 is for the 520-Series with the swept forward front axle.
The 418 lists blade 06-48BC01 or these that followed 06-48BC02, 06-48BC03, 79350 and 79364. These should give you an idea what the lever looks like.
https://lookup3.toro...fm?xCaller=Toro
Garry
  • MH81, shallowwatersailor, caseguy and 1 other said thanks
#9 MH81 OFFLINE
Posted November 14, 2011 - 01:10 PM
Thanks Garry, I was a little out of my depth here LOL
#10 WH1056 OFFLINE
WH1056
  • 64 Thanks
  • 59 posts
Posted November 14, 2011 - 05:40 PM
That is actually the dozer blade that came with a 1990 520-8 I sold a few years ago.
I use one just like it - minus the extension kit - on my GT-1848 or my 416-H
There were quite a few variations of angle levers used over the years and sometimes just flipping them over will allow them to clear the footrest.
#11 MH81 OFFLINE
Posted November 14, 2011 - 08:04 PM
Now that's good info, thanks... I was hoping some smart WH guys like you two would find this thread LOL
Sorry about stealing the pic, where I found it, I thought it was labeled as a 414-8 plow.
#12 truck21 ONLINE
truck21
  • 503 Thanks
  • 286 posts
Posted November 15, 2011 - 10:33 PM
Ok problem solved, with a little help from two good friends ( Victor Torch and Bench Vice ) we got the blade working like a charm. Now on to the next issue. THANKS TO ALL FOR YOUR HELP!!!!
THANKS DON.
#13 MH81 OFFLINE
Posted November 15, 2011 - 11:10 PM
Good to hear it! How about a picture of it on the 414?
#14 truck21 ONLINE
truck21
  • 503 Thanks
  • 286 posts
Posted November 16, 2011 - 12:40 PM
I would love to post a pic if I was smart enough to figure out how. I see you are in Cochranton Pa, how far is that from Lancaster or Harrisburg ?
THANKS DON.
