54" plow cylinder ?
2 replies to this topic
#1 saintb OFFLINE
saintb
  • 23 posts
Posted November 13, 2011 - 02:34 PM
Where do I buy an articulation cylinder for the JD 54" plow? any idea what the part# is?
thanks
#2 Littledeere OFFLINE
Littledeere
  • 1,658 Thanks
  • 1,487 posts
Posted November 13, 2011 - 03:43 PM
You will need part number Am31362 cyl and brackets am31368 and am31369
It will be good if you can find a set on Ebay last I heard Deere want's a pretty good price for them. The lift cyl is the same so if you find a lift cyl it will work if you already have the brackets
Edited by Littledeere, November 13, 2011 - 03:58 PM.
  • saintb said thank you
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 13, 2011 - 05:19 PM
One caveat about the lift/angle cylinder. Sometimes the plumbing fittings for the hose routing, and the hose length are not the same on the angle cylinder as the lift cylinder. You should verify they are the same or at least recognize and be able to deal with any differences.
