3 toro Diesel Fairway mowers
This topic has been archived. This means that you cannot reply to this topic.
3 replies to this topic
#1 MH81 OFFLINE
  • 29,979 Thanks
Posted November 12, 2011 - 08:02 PM
3 Toro mower Fairway mowers
#2 olcowhand ONLINE
  • 43,118 Thanks
  • 31,998 posts
Posted November 12, 2011 - 08:41 PM
Buy em Alan. Put a diesel into the ugly Massey, then you'd have an "Ugly BEAST"!
#3 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,166 Thanks
  • 1,332 posts
Posted November 12, 2011 - 09:08 PM
It looks like two Toro Reelmaster 223Ds which had the three cylinder Mitsubishi engines in them and are known in the industry as pretty much junk engines. Very weak bottom ends and in constant need of valve adjustments and cam wear if the valves get too loose.
Hard to see the number on the third machine since it has a taller hood if it is a Reelmaster 5100D the engine should be a normally aspirated three cylinder Kubota and if it is a Reelmaster 5300D the engine should again be a three cylinder Kubota but turbocharged.
In all three hydrostatic drive with a separate multi-section pump to run all the hydraulics including the reels.
#4 olcowhand ONLINE
  • 43,118 Thanks
  • 31,998 posts
Posted November 12, 2011 - 09:12 PM
Great info on the Mitsubishi diesels Bill!
