brinly wing disc
31 replies to this topic
#1 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted November 12, 2011 - 06:46 PM
just got started but here are a few pictures . it is a brinly 4' dual gang disc but just did take the tracks out on the 400 so i added wings now it will be 6' . 2011-11-12 15.45.31.jpg
#2 Alc OFFLINE
  • 7,226 Thanks
  • 7,578 posts
Posted November 12, 2011 - 06:52 PM
That's going to be a great looking disc when your done , Al
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted November 12, 2011 - 07:34 PM
Your discs look great. Will make a big difference both in time and working your tractor. Your only a couple of feet shy of a set of Ferguson farm discs we had. Dad started farming with a set of 8 ft discs.
#4 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted November 12, 2011 - 08:48 PM
its mostly done i have a few things to clean up and a few welds to do and figure out how to get cylinders on it to pick them up and put them down . got to get it sand blasted and painted then should look good .
#5 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted November 12, 2011 - 09:01 PM
Awesome build! One cylinder connected to two risers, one from each wing should do it. If it raises one side faster than the other it wouldn't matter, as once one reached top, then the other would follow. Cheaper with just one cylinder. You'd just need to know what length cylinder you'd be using, then make the risers the right length so the wings would bottom & top just right.
#6 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted November 12, 2011 - 10:10 PM
wing lift ideere real rough sketch
#7 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted November 12, 2011 - 10:15 PM
What I was meaning was for the hydraulic cylinder to attach directly to the risers, each riser being around 1' tall. The cylinder would just mount simply between the risers.
#8 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted November 12, 2011 - 10:23 PM
but would that pull them all the way up ? ill do some measuring tomorrow to see if it will . i know what your saying though and yes that would be idea
#9 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted November 12, 2011 - 10:26 PM
You would have to get the height of the risers "just right" for it to work, but it will work. You'd likely need a 20 to 24" stroke cylinder.
Each riser would need a "stop block" at full lift position, so one side wouldn't "over center".
#10 KennyP ONLINE
  • 40,881 Thanks
  • 47,093 posts
Posted November 13, 2011 - 06:35 AM
This is cool. Great job on the extensions! I'll be lurking for the updates.
#11 ckjakline OFFLINE
ckjakline
  • 1,144 Thanks
  • 1,135 posts
Posted November 13, 2011 - 08:28 AM
Nice looking disc!
#12 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted November 13, 2011 - 08:32 AM
Wow! That's quite a disc!
#13 plowboy OFFLINE
plowboy
    TRACTOROLOGIST
  • 133 Thanks
  • 229 posts
Posted November 15, 2011 - 12:11 PM
love it!! looks amazing....you're on a roll there...literally..lol. i can't think of much that wont handle!
#14 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted November 15, 2011 - 12:27 PM
That is a great looking disc.
#15 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 15, 2011 - 02:41 PM
Have you made any progress on the wing lifting methods yet Gary?
