Ready for winter! I hope
38 replies to this topic
#1 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 316 posts
Posted November 10, 2011 - 07:27 AM
Well, here she is wearing her winter gear. Serviced the blower with a few shots of grease, adjusting drive chain tension, and will wire wheel and paint the inside of chute today. The 110 is fully serviced and ready to go! I put tire chains on after I took photos.
#2 KennyP ONLINE
  • 40,901 Thanks
  • 47,101 posts
Posted November 10, 2011 - 07:46 AM
Looks good! I hope I don't need one of those down here this winter.
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted November 10, 2011 - 08:00 AM
Now for some white stuff to play with. No hurry tho...
#4 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 316 posts
Posted November 10, 2011 - 08:15 AM
You got that right! Just because I have a fire extinguisher in my home don't mean I want a fire! LOL!
#5 MH81 OFFLINE
  • 29,978 Thanks
Posted November 10, 2011 - 08:25 AM
AMEN! I can wait, we'll have lots of time.
#6 twostacks OFFLINE
twostacks
  • 490 Thanks
  • 446 posts
Posted November 10, 2011 - 08:29 AM
Looks good. Do the single stage blowers throw the snow pretty well? Call it wishful thinking but I usually wait until the snow is flying to put mine on. I get everything serviced and make sure that I have gas but I don't put the blower on until I have to. Gary
#7 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 316 posts
Posted November 10, 2011 - 08:38 AM
Not a clue. This is my first tractor mounted blower. I have heard the single stage blowers work terrific in dry, loose snow. Not so good in heavy, wet snow. Then again the same thing can be said for any blower, single or two stage. Here in ND our snow is almost exclusively dry anyhow. She should serve me well. I also have a plow on my four wheeler.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 10, 2011 - 08:52 AM
Based on my experience last year with my first GT mounted blower on my 318. I would say the single stage does well depending on the type of snow you have. Powder blows very well. Slushy snow not well at all. The single stage seems to work better the deeper the snow is.
Since you don't have a slinger to throw the snow you need to keep the auger loaded. Guaging ground speed to snow load is the key.
An ideal scenario would be to have a second tractor with a blade to move the 1" snows and heavy wet slushy stuff.
We got 2" of heavy wet stuff tuesday night, I did not blow it. It melted yesterday.
#9 Brett OFFLINE
Brett
  • 78 Thanks
  • 287 posts
Posted November 10, 2011 - 10:06 AM
Looks good. Hopefully you won't need to use it for a while.
#10 Deere Green OFFLINE
Deere Green
  • 24 Thanks
  • 126 posts
Posted November 10, 2011 - 10:20 AM
Nice, if I end up with this 317 I hope to find a blower for it as well.
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 10, 2011 - 11:31 AM
You look ready. I find that I like to use a blade for most snow falls. On a gravel driveway I can scrape it down and keep ice to a minimum. There's nothing like a blower for large snowfalls though.
#12 daytime dave ONLINE
  • 4,967 Thanks
  • 6,598 posts
Posted November 10, 2011 - 11:37 AM
You will enjoy the blower. The single stage is a good unit if you follow JD Dannels good advice in his post. Hope it gives you many fun hours in the seat.
#13 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 316 posts
Posted November 10, 2011 - 12:07 PM
There! I installed the plow on the wheeler and sanded and repainted the inside of the discharge chute in the blower. This is my snow fighting equipment.
#14 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 10, 2011 - 12:41 PM
There You Go!! wish I had a Quad to supplement my 318 blower!
#15 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 10, 2011 - 01:23 PM
One other quick tip: Rode Hard and put up wet applys to your blower too. When you put it away be sure to get all the ice slush and snow out of the works. For two reasons, you don't want it melting on your garage floor and you don't want it freezing, so when you put it in gear it shears the shear bolt(Keep a couple extras on hand).
JD Brian says he prefers the blade and I agree most of the time. The problem I see with a blower is that more often than not the place where you need to pile the snow is upwind of you and you look like the abominable snowman when you get off the machine. It's normally cold enough without blowing snow down your neck.
  • akretowicz said thank you
