wheelhorse snowblade
12 replies to this topic
#1 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted November 08, 2011 - 08:48 PM
I'm not sure how this bracket works at the back of the tractor,so i was hoping someone could help me with this.[I hope i got the right plow]
#2 MH81 OFFLINE
Posted November 08, 2011 - 10:35 PM
There are 2 members looking for the info (specifically the part # and assembly instructions). With a little luck, one of them finds the info you need.
  • tractorman604 said thank you
#3 ONEROADKINGMAN OFFLINE
ONEROADKINGMAN
  • 1 Thanks
  • 10 posts
Posted November 09, 2011 - 02:41 AM
What model tractor do you have ? The bracket clamps around the rear end with the levers pointing down.the rod at the end of the plow hooks up to that. Then the other rod hooks up to the lift arm.hope that helps ya.
#4 MH81 OFFLINE
Posted November 09, 2011 - 07:20 AM
Chatting with another WH owner, he said that most of them mount the same way, but some of them are different. He said that there were several different versions of the bracket and (in his case) the Commando he owns is different from everything else. The 800 wasn't that long after the Commandos and it may be different as well.
#5 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted November 09, 2011 - 09:05 AM
This plow fits a 953 and a 1054. My tractor is a 1971 800 special,so i hope that it is suppose to fit. Thanks for helping!
#6 GWest OFFLINE
GWest
  • 553 Thanks
  • 504 posts
Posted November 09, 2011 - 09:11 PM
If you take the latches off the brackets that came with the plow will they fit the bracket already on the rear axle?
The blade listed for the 1-0150 came in 2 packages. 6-4113 and 6-9622
What is the model and serial number on the frame you have?
Garry
#7 MH81 OFFLINE
Posted November 09, 2011 - 09:29 PM
BD-546.jpg I think this is the plow you should have.
If so, it may be that all that is missing to make this one work are the little lock handles on your existing brackets. Looks like you can transfer those tho. I also think the lift "Rod" needs to be changed to one like in the manual.
If you have the original WH model number for the plow, it may help verify that. Download this manual & see if you agree: BD-546 Dozer Blade - Manuals - Garden Tractor Talk - Forums
Edited by MH81, November 09, 2011 - 09:56 PM.
  • tractorman604 and caseguy have said thanks
#8 MH81 OFFLINE
Posted November 10, 2011 - 12:59 PM
Also, here is the parts list for your tractor, it shows parts of the hitch and probable orientation.800 Auto Special - Manuals - Garden Tractor Talk - Forums
#9 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted November 10, 2011 - 04:11 PM
Guy's, thank's for the help. It seem's all i needed was to take the latches off the bracket and put them on the rear axel,So everything is good and i'm ready for winter. Thank's again!
#10 GWest OFFLINE
GWest
  • 553 Thanks
  • 504 posts
Posted November 10, 2011 - 04:27 PM
Curious to know how you ended up with the notches in the rear frame. I suspected it was a hitch for a rear tiller but no tiller listed for the 1-0150. Is that frame something someone welded up? I looks factory supplied in the pictures.
Garry
#11 WH1056 OFFLINE
WH1056
  • 64 Thanks
  • 59 posts
Posted November 10, 2011 - 05:40 PM
Garry
It's an 800 Special with the Peerless transaxle. The rear frame section is totally different than the tractors with the Wheel Horse Uni-Drive.
#12 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted November 10, 2011 - 08:09 PM
The holes were there, and everything just fit like a glove.It was that bracket that i didn't need that was confusing me ,i just needed the lever latches.I spread a pile of topsoil tonight and it worked great,not sure if that blade is only for snow but it worked really good on the soil.[Anything for seat time]
#13 MH81 OFFLINE
Posted November 10, 2011 - 08:23 PM
Rule of thumb, if the Plow mounts to ( or attaches near ) the rear end, it's for Dirt or snow. Pretty much anything you can push. If it attaches to the front only, it's just for white fluffy stuff.
Obviously, a generality... but yours is definitely a "Dozer Blade" and very capable of doing light dirt work.
