cub cadet 149 needs help
5 replies to this topic
#1 whitelt120 OFFLINE
whitelt120
  • 17 Thanks
  • 119 posts
Posted November 07, 2011 - 03:44 PM
My cub cadet doesen't have a spark I checked the coil and from what I know it is wired up right if anyone could help it would be appreciated:worshippy1:. I have no clue what is wrong
#2 jweaver OFFLINE
jweaver
  • 5 Thanks
  • 22 posts
Posted November 07, 2011 - 04:14 PM
are the points good and set at 20 th top dead center if so check the condencer and then the coil
#3 whitelt120 OFFLINE
whitelt120
  • 17 Thanks
  • 119 posts
Posted November 07, 2011 - 05:26 PM
ok I ll try that thanks
#4 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted November 07, 2011 - 07:32 PM
It could be the Spark plug wire also.
#5 Kyocum ONLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted November 07, 2011 - 11:57 PM
Do you have 12 volts at the coil? Dont rule out a bad spark plug esp. if it is a champion. Kohlers like autolite spark plugs.
#6 whitelt120 OFFLINE
whitelt120
  • 17 Thanks
  • 119 posts
Posted November 08, 2011 - 01:07 PM
It s not the spark plug because I tested it fron the wire and it still had no spark . Ill try a different wire , and i think i have 12 volts at the coil.
