Putting Hydro Gear Back on the Tractor
3 replies to this topic
#1 Contsi OFFLINE
Contsi
  • 6 posts
Posted November 05, 2011 - 09:24 AM
I replaced the brake shaft on the transaxle and a couple of questions before I put it back in.
I removed the axle horns, I opened the transaxle and replaced the shaft and put it back together. I left everything the same way, everything looked ok.
The pulley on the pump is moving freely, I can also spin the shaft by spinning the brake disk, is this normal? anything I can do to make sure it is ok to go back on? Other than adding the oil (2 quarts of Castrol 20/50) put it back on the tractor and see if it engages.
Thank you
#2 Contsi OFFLINE
Contsi
  • 6 posts
Posted November 07, 2011 - 08:21 AM
I got the transaxle back on the tractor, jacked it up started it and got motion in both directions, I'll finish putting it together and try driving it. Thanks for all the help.
#3 ducky OFFLINE
  • 1,826 Thanks
  • 3,995 posts
Posted November 07, 2011 - 08:33 AM
Thx For the update.
Sounds like you have it under control.
#4 MH81 ONLINE
  • 27,990 Thanks
  • 28,944 posts
Posted November 07, 2011 - 12:31 PM
Sorry I missed the thread, glad you were successful.
