testing solid state wiring sytsem 1969 john deere 140
9 replies to this topic
#1 jdingersoll OFFLINE
jdingersoll
  • 9 posts
Posted November 03, 2011 - 07:55 PM
Hello JD guys,
Is there a testing procedure for my electrical system on my 69 JD 140 with solid state wiring system?
I'm having real trouble over here. She'll turn over with the key. But no spark.
I have a test light and a multimeter. Don't know how to use either. If there is someone that could guide me. I'd be very appreciative.
Sincerely,
jdingersoll
#2 MH81 OFFLINE
Posted November 03, 2011 - 09:18 PM
I can't help with JD specifics, but what engine is in it?
#3 Trav1s ONLINE
Trav1s
  • 3,509 Thanks
  • 4,492 posts
Posted November 03, 2011 - 09:55 PM
It sounds like you need a service manual.
FWIW - my initial thought was bad ignition switch and the correct one is determined by the serial number of the tractor. Hapco sells for tractors serials up to 10000. If I read your post correctly JDParts gives this info for your tractor:
AM102544 SWITCH 1 10001 - 22400 IGNITION (5-PRONG, SOLID-STATE TRACTORS)
Here is the image from the parts site
#4 jdingersoll OFFLINE
jdingersoll
  • 9 posts
Posted November 04, 2011 - 07:57 AM
It's a K321. Is there a testing procedure for the entire electrical? I dont want to spend money guessing.
#5 ducky OFFLINE
  • 1,988 Thanks
  • 4,107 posts
Posted November 04, 2011 - 08:47 AM
All I have a manual for is the old Point/Coil system.
Perhaps some one has the newer manual and can help you out.
#6 olcowhand OFFLINE
  • 42,289 Thanks
  • 31,764 posts
Posted November 04, 2011 - 02:25 PM
Those Kohler ignitions are far & few between & I hear almost impossible to troubleshoot. I used to have a Wheel Horse GT14 that had the solid state ignition. Luckily it never gave any problems. The Kohler site's download for the 321 has this solid state ignition in their service manual.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 04, 2011 - 03:30 PM
If you have a copy of the K321 service manual it has a pretty detailed description of the kohler SS ignition and some tests you can do on it. I'm not sure if JD used the stock Kohler part but it would be a good starting point.
#8 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted November 04, 2011 - 06:30 PM
Looks like an easy system to troubleshoot. You have all youll need
#9 jdingersoll OFFLINE
jdingersoll
  • 9 posts
Posted November 05, 2011 - 08:15 PM
Hey JDBrian,
Do you have a copy of this K321 service manual you could email me?
Sincerely,
jdingersoll
#10 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted November 05, 2011 - 08:22 PM
www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
