MF 10 restoration begins!
193 replies to this topic
#31 coldone OFFLINE
coldone
  • 1709 Thanks
  • 1709 posts
Posted November 13, 2011 - 09:46 AM
They are 6" rims off a wheel barrow.
I meant the ones on the front axle that you took off. I need 18X8.5x8 rims.
Thanks
#32 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 13, 2011 - 07:10 PM
I will go look after dinner.
#33 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 13, 2011 - 07:19 PM
I worked 8 1/2 hours on it today. Most of the time was sandblasting parts. I got everything sand blasted and primed. I worked on putting the vari speed control back together and mounted the front wheels on the spindle. I did a lot of measuring and bending and cutting getting the steering link right. I started working on the 3 point hitch. I made the lift shaft bearing holders and figured out how to hook the lower lift arms up. That will be a lot of work but should look clean when I am done. Tomorrow I will get some more parts so I can continue on it. I am on schedule and moving right alongPB130058.jpg
#34 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 13, 2011 - 07:52 PM
@ Coldone I went out and looked and the tires are 16 6.50 X 8
#35 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted November 13, 2011 - 08:07 PM
Dan that is looking fantastic,you'll be really proud of yourself when it's done! by the way your rj on your avatar.........WOW!
#36 coldone OFFLINE
coldone
  • 1709 Thanks
  • 1709 posts
Posted November 13, 2011 - 10:30 PM
Thanks for checking.
That tricycle front looks great.
#37 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 15, 2011 - 08:44 PM
I didn't do much the last 2 nights. I have been having shoulder problems so today I went to the Doc and he gave me a shot with a big long nasty needle in my shoulder. It is pretty sore. I did get most of the parts rounded up to make my 3 point hitch so that will be my next part of the projectPB150061.jpg
#38 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 15, 2011 - 08:50 PM
You're quite the trooper. You just keep pluggin along.:thumbs::thumbs:
Keep it up.
Lookin forward to more updates.
#39 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted November 15, 2011 - 10:06 PM
Wow, you're really making progress. The 3 pt will be sweet!
#40 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 16, 2011 - 09:29 PM
I worked on it for a while tonight. I got the steering link all hooked up. It took some bending, cutting, measuring, and welding but I got it donePB160063.jpg
#41 tractormike OFFLINE
tractormike
  • 179 Thanks
  • 1488 posts
Posted November 17, 2011 - 10:26 AM
Your project is coming along very well Dan, NICE WORK! Keep us updated.
#42 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted November 17, 2011 - 06:09 PM
Lookin good keep up the good work.
#43 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 17, 2011 - 09:46 PM
PB170065.jpg I worked on it for about an hour tonight. I got the first lower lift arm bracket made and part of the other side done. This weekend I hope to have all the 3 point done. I hope!
#44 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 18, 2011 - 09:12 PM
I worked on the 3 point again tonight. I got both lower arm mounts made and bolted on. I welded the ball ends to one end of the lower lift arms and put them in the brackets. I started to figure out the upper lift arms but decided that was better left for morning when my brain is fresh. This will take some figuring out. I feel like I am not getting as much done but it takes time to invent as you go along.
#45 KennyP OFFLINE
  • 50116 Thanks
  • 52292 posts
Posted November 19, 2011 - 05:12 AM
Looking good, Dan. Just keep plugging along, you'll get there. I usually mess up when I get in a hurry to finish.
