MF 10 restoration begins!
193 replies to this topic
#16 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted November 08, 2011 - 09:08 PM
wheels look good.I think the older masseys w/the red centers look good.Really sets the wheel off.
#17 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 10, 2011 - 10:21 PM
I worked 2 1/2 hours on it tonight. I put the wheels on the rear. I had to take a tap and clean out all the bolt holes as the tractor was buried in the dirt and these were all full of dirt and rust. It looks pretty cool with those big tires on it. Then I started making the front spindle. I figured out the length ( I hope) and then bored the hole for the front axle. I had to ream out the bushing so the 1" shaft would fit as it was a little undersized. The next step will be to get the plate welded on the bottom and the spindle shaft in place. This will take some work to get it all straight and true. This is the fun part.
Edited by DanP, November 11, 2011 - 09:09 AM.
#18 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted November 10, 2011 - 10:37 PM
Nice look Dan, cool lathe too!
#19 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 11, 2011 - 09:49 PM
I worked a couple more hours on it tonight. I put the plate on the bottom to get the hole right for the spindle shaft. Then I welded a large washer onto the outer spindle housing to make a bearing surface. I am going to use a nylon bearing in between the plate and washer so I don;t have to oil it. Less grease running down the front tires. I am going to put a 1" shaft collar on top of the plate and weld it to the plate. Then I made the shaft long enough to reach the frame. I am going to drill a hole in the frame and the shaft and bolt the shaft to the frame. This will give it two support areas and it will allow me to change the shaft if I ever bend it. This will make more since when I take a picture of it.PB110040.jpg
#20 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 12, 2011 - 09:04 PM
I worked all day on the MF10. I finished the front spindle putting a heavy collar on top of the plate for the shaft to run through and then bolted the top of the shaft to the frame. I put the axles in the spindle and machined a grove for an expansion plug to keep grease from running down the spindle onto the tires. I put a grease zerk in the back side of the spindle. Then I had to get the shifter and indexer for the vari speed off the shaft. It was really stuck, I had to take it to the press to get it off. I drilled a hole and put a grease zerk in it so this won't happen again.I cut out the nylon bearing for the spindle and made a spare which I will forget where I put it.Then I sand blasted a lot of parts and the frame. A coat of primmer and I am done for the day. PB110045.jpg
#21 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 12, 2011 - 09:09 PM
You're doing an awesome job there. Thanks for the update.
Also, thanks for the laugh. "I made a spare, but forgot where I put it" LOL LOL
Keep up the good work.
#22 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 12, 2011 - 09:12 PM
I wish I could get this photo thing down. I get them scattered all over the place.
#23 olcowhand OFFLINE
  • 44097 Thanks
  • 32301 posts
Posted November 12, 2011 - 09:41 PM
Looking super thus far! Isn't that an Atlas lathe? I had an Atlas 10x36 before I got my South Bend 10x42. Both great lathes!
#24 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 12, 2011 - 09:56 PM
Yes it is an Atlas, we have had if for over 50 years and it still works pretty good.
#25 coldone OFFLINE
coldone
  • 1709 Thanks
  • 1709 posts
Posted November 12, 2011 - 10:06 PM
What size are the front rims? I need a set fro my 1650.
Great work, I am in the process of restoring my 1650A. I only get to spend a few hours each week on it. I wish i could make progress on it like you are on yours.
#26 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 12, 2011 - 11:03 PM
They are 6" rims off a wheel barrow.
#27 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1531 posts
Posted November 13, 2011 - 01:48 AM
That's coming along nicely. I enjoy seeing/reading about projects like this. I don't have the space or the shop area to do a rebuild like this, but it sure gives me some good ideas. Thanks!
#28 mjodrey OFFLINE
  • 2373 Thanks
  • 13481 posts
Posted November 13, 2011 - 05:48 AM
You are making good headway,thus far.
#29 KennyP ONLINE
  • 50110 Thanks
  • 52289 posts
Posted November 13, 2011 - 06:04 AM
Looking good. I have a question though. Are the front wheels going to be standing straight up or leaning some what? Can't tell for sure. Something like this:
#30 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted November 13, 2011 - 06:26 AM
They are going to be straight up.
