wireing harness help
3 replies to this topic
#1 player92my3 OFFLINE
player92my3
  • 1 Thanks
  • 19 posts
Posted November 01, 2011 - 08:03 PM
Okay i just got a older briggs 19.5hp engine. Formally in a craftsman riding mower. the model is: 42E707-2631-E1 Okay so i am lifting a sears tractor and puting this engine in it. i do my own wiring so ill completly rewire it i just need to knpw what The plugs comming out of the engine are for. heres a link to what the engine is: http://images1.ameri...ia_14162233.jpg
NOTE: not my engine, but same one thanks for the help :D
#2 Rivets OFFLINE
Rivets
  • 1 Thanks
  • 2 posts
Posted May 10, 2012 - 07:34 AM
Can you post pics of the plugs you are referring to? Tell us the color of wire also. This will make it easier to explain what each wire is for. Thank.
#3 MH81 OFFLINE
Posted May 10, 2012 - 05:06 PM
I found very little info on that engine wiring wise, but I did find that they used that engine in the 917.259573 tractor. I did find a wiring diagram for that tractor. Hope this helps.
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 10, 2012 - 07:37 PM
Word of advice on these wiring diagrams. The "IGNITION UNIT" is more than likely a MAGNETO, so DO NOT feed it 12 Volts, or you will be sorry. Trust me, I rewired an older Briggs in a Craftsman and read "ignition unit" as if it were an "ignition coil" requiring 12 Volts and gave it such... and boy was I sorry when I had to replace the 50 dollar magneto that I FRIED!!! Just want to warn you of that before you do it, because I was definitely sorry I did that....
