sloppy Steering
10 replies to this topic
#1 Brett OFFLINE
Brett
  • 78 Thanks
  • 287 posts
Posted October 31, 2011 - 07:32 PM
Question... My front right tire doesn't seem as tight (for lack of a better way to describe it) as the left especially when turning sharply. Could this be ball joints? I have replaced wheel bearings earlier this year. Or would you say tie rod and that spindle?
#2 MH81 OFFLINE
Posted October 31, 2011 - 08:17 PM
Often, units will have a different steering radius one way vs the other. I believe it has something to do with the mowing. If it discharges on the right, it will turn sharper to the left for getting in closer to stuff.
#3 Brett OFFLINE
Brett
  • 78 Thanks
  • 287 posts
Posted October 31, 2011 - 08:30 PM
thats a good point. somthing just doesn't seem right with the right wheel though. A good example would be lets say I'm going to go over a tree root while turning slightly that tire will move all the way to the inside or outside depending on which way i'm turning with little resistance what so ever. I don't know if that helps any. Being a 185 could it just be that the components just aren't that strong?
#4 dave8338 OFFLINE
dave8338
  • 196 Thanks
  • 374 posts
Posted November 01, 2011 - 06:45 PM
Is it moving on the spindle (sliding in and out), or at the tierod end?
Also, on my 116's, the primary steering spindle is on the left and IT, is connected to the right by the drag link. Since there are 3 tierod ends in play (2-on the drag link and 1-on the left spindle), the right front tends to move more as a result of wear on the tierod ends.
Edited by dave8338, November 01, 2011 - 06:50 PM.
#5 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted November 01, 2011 - 07:01 PM
Something that I found on old mower once was the piece the tierod end fastens to was bent down, You could mow until it was just right and the tire would go all the way out spread eagle.
#6 Brett OFFLINE
Brett
  • 78 Thanks
  • 287 posts
Posted November 02, 2011 - 09:11 AM
I am starting to think my problem may be from or in part due to my drag link. I will try to upload a photo of whats going on to see what ya'll think. I think that will be easier than trying to explain it.
#7 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 02, 2011 - 10:38 AM
You need to inspect all the tie rods, bearings, bushings spindles etc in the steering linkage. If they are all worn it can add up to a lot of slack in the steering. Also the axle, and it's pivot bolt/bearing should be inspected as well.
#8 olcowhand OFFLINE
  • 42,524 Thanks
  • 31,838 posts
Posted November 02, 2011 - 10:54 AM
Sounds like worn pivot points. We'll wait for pics.
#9 Brett OFFLINE
Brett
  • 78 Thanks
  • 287 posts
Posted November 03, 2011 - 08:15 PM
Here is the best picture I could get. This seems to me like the root cause to my steering issues since it isn't seated flush it puts stress on the left front in turn effecting the right. Does this make sense?
#10 Brett OFFLINE
Brett
  • 78 Thanks
  • 287 posts
Posted November 03, 2011 - 08:43 PM
Glad I got the picture up. My computer didn't like me tonight.
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 04, 2011 - 10:06 AM
It's hard to see what is going on in the picture. I would jack up the front of the tractor and grab each wheel and wiggle it to see where all the slack is coming from. You should be able to watch the various parts in the steering system and see whats what.
