Newbie
13 replies to this topic
#1 Birge77 OFFLINE
Birge77
  • 3 posts
Posted October 28, 2011 - 10:04 PM
Newbie here,
Just looking around very nice site. Have a Jacobsen Homelite same as a Ford LGT 145
Looking for Spindles for the Mower Deck.
Also have an Ingersoll 3010.
#2 MH81 OFFLINE
Posted October 28, 2011 - 10:06 PM
Birge77, :welcometogttalk:
Glad you found us, sounds like you have a couple of nice tractors.
#3 caseguy OFFLINE
  • 1,627 Thanks
Posted October 28, 2011 - 10:23 PM
:wave: Birge77 Welcome to GTTalk! Nice to have you here! We can see the Ingersol in your avatar, but we'd love to see some pics of the Homelite too! We hope that you enjoy the forum and thanks for signing up!
#4 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
:welcometogttalk:
#5 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted October 29, 2011 - 06:00 AM
Welcome to GTT !
What happened to the spindles ? They are totally rebuildable on those rigs. Unless of coarse it is bent , or the keyway slots wallowed out, in this case you can make new shafts or 8 should say, have them made. Bearings are easy to find at any good bearing shop, heck any good laborer shop should have them as well. If your pulleys are gone.... well this it much more difficult to fix or find. Good luck and post some pics , and remember we are here to help.
#6 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted October 29, 2011 - 06:15 AM
Welcome, Birge77! Pic help can be found here if you need it: http://gardentractor...res-gttalk-209/
We like to see what you have and that can really help when suggesting fixes. Have you checked out the 'Manuals' section yet? Is the Homelite an open or closed side tractor?
#7 mjodrey OFFLINE
Posted October 29, 2011 - 06:37 AM
Birge77,welcome to the forum.
Glad to have you with us.
Nice looking Ingersoll.
#8 Birge77 OFFLINE
Birge77
  • 3 posts
Posted October 29, 2011 - 12:16 PM
The attached are pictures of my newly acquired Jacobsen Homelite TextronUT34003 GT14 H, basically the same as a Ford LGT 145.
I got this because my Ingersoll is down right now and I needed something to pull the leaf sweeper with. I got it off Craig’s list for fifty bucks in non-running condition. The PO said it had quit on him and he didn’t feel like fixing as he had another GT I think I saw a cub while there. Anyway, the hood and sides were on the tractor so I lucked out there, I noticed immediately that the coil and condenser were gone, also that the wiring harness was a mess. He was asking 70,I talked him down to fifty.
When I got it home I ordered a new keyed ignition switch as the PO had tried to wire in a dip switch on /off. I replaced the coil, condenser, and put new points and a spark plug wire and a fuel pump. It fired up ran run for a while until I cleaned the carb out real good. This was two weeks ago I purchased, last weekend I pulled the sweeper around a bunch it does well, today I am draining the hydro and changing the filter tightening up the brakes. I already changed the oil last weekend before I worked her.
Anyway also this week I took the deck off and apparently sitting in a field uncovered for five years cause a deck to seize up, who knew? Anyway, the tops of the spindles are about rusted through, the deck isn’t to bad, but the spindles need work, while pressing the bearings off I bent the otherwise rusty tops up and not sure the blades will ever be parallel to the ground again if I put them on.
The Jake doesn’t have to mow as we have ended that part of the season. But my wife can drive the Jake better than she can drive the Ingersoll. She’s not real good with the Hydriv lever on the dash and prefers the foot pedal.
So that’s my story I look forward to reading others, I’ll keep you posted on the progress
Birge
Edited by JDBrian, October 29, 2011 - 04:10 PM.
corrected typing errors
#9 JDBrian OFFLINE
  • 9,606 Thanks
  • 14,142 posts
Posted October 29, 2011 - 04:10 PM
Nice tractors you have there. Welcome to GTtalk.
#10 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted October 29, 2011 - 05:13 PM
Don't know what to say about the deck parts. Will have to look around some. Not a bad looking tractor. What's the problem on the Ingersol?
Is this a 42" deck? I checked with Messicks and the spindles are still available, just made with some gold in them.
I used my deck #, 09jc9835 to find this. They are the same from 1972 on.
Edited by KennyP, October 29, 2011 - 05:20 PM.
#11 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted October 29, 2011 - 07:10 PM
Welcome to GTtalk. Sounds like you have a real good start on soon to be large collection.
#12 Birge77 OFFLINE
Birge77
  • 3 posts
Posted October 30, 2011 - 07:03 PM
Thanks All
Kenny I looked at New Holland and Messicks I think my problem was I didn't have a model number for the deck. Its Good to know from 72 on they are the same. I saw some on New Hollnad and they too must have been made of gold with diamond encrusted threads. I'll keep my eyes open.
Attached are a few shots of the Ingersoll and the trailer
The ingersoll was also had for very little money I bought it a couple of years ago for 225 on craigs list it ran but it knocked a little, well the knock got worse and turned out to be a rod. I repalced the rod, but I think its possible I gto the lubrication hole on the wrong side as it threw the rod again. Still no major engine damage but it rattled my confidence enough to let a friend rebuild it. And so I am still waiting on it.
Edited by Birge77, October 30, 2011 - 07:11 PM.
guess I forgot pics and the laptop died
#13 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 30, 2011 - 07:30 PM
Welcome aboard Birge77
#14 Brett OFFLINE
Brett
  • 78 Thanks
  • 287 posts
Posted November 23, 2011 - 12:18 PM
Welcome to the site!
