7016 hydrostat
3 replies to this topic
#1 harlan OFFLINE
harlan
  • 9 posts
Posted October 27, 2011 - 08:52 PM
my tractor will not move until engine has been running about 5 minutes. then hydro transmission works fine. any ideas about a cure?
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted October 27, 2011 - 09:33 PM
You might want to do a fluid & filter change. If that's not it, you are probably going to have to get into it.
#3 cityboy2977 OFFLINE
cityboy2977
    ordinary average guy
  • 117 Thanks
  • 179 posts
Posted October 28, 2011 - 03:57 AM
yep, i would start with a fluid and filter change. also might want to do a bevel gear box change also. or at least make sure fluids are up to level.
NAPA will have your filter for about $9-$11...i used Dextron III type F trans fluid in mine....80w-90 oil for the BGB.
good luck...hope you get 'er running properly.
#4 mjodrey OFFLINE
Posted October 28, 2011 - 04:30 AM
Yes that would be the first thing I would do ,too.
