316 charging system
1 reply to this topic
#1 canvasguy OFFLINE
canvasguy
  • 1 posts
Posted October 27, 2011 - 10:06 AM
I have an older 316 with an onan engine. The battery light stays on and is not charging.Any advice on where to start. Thanks.
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted October 27, 2011 - 10:34 AM
You need to check the connections at the regulator and the connection from the motor to the - battery terminal. A bad connection anywhere in there will cause grief with the charging. I would also verify that the battery is good by charging it on a charger and then load testing it. After you know all your connections are good and you have a healthy battery you can look at the battery voltage to see if there is any charge being delivered by the regulator.
