scared to ask 140
5 replies to this topic
#1 Dennisdeny OFFLINE
Dennisdeny
  • 3 posts
Posted October 26, 2011 - 04:54 PM
I recently purchased a 140 H1 and the rear PTO /fan only turns occationally with a loud squeeling noise. Is this fan not always supposed to turn?
#2 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted October 26, 2011 - 05:32 PM
it is suppose to turn all the time but i never had one off so im not sure if its has splines or keyed .
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 26, 2011 - 06:07 PM
If you have a 140 with a ser. no greater than 30000 it should have a fan that is attached to the shaft with a 1/4" roll pin. It is unlikely to break. The problem could be on the other end of the shaft where it is coupled to the driveshaft. The hydro may not be turning due to a damaged coupling or input shaft. This is not good news. You need to check it right away.
#4 140 OFFLINE
140
  • 3 Thanks
  • 13 posts
Posted October 26, 2011 - 06:53 PM
Agree with JDBrian. Removing the fender pan will give you a sure fire way to find why it isn't spinning. Is the tractor still able to move when the fan stops?
#5 Dennisdeny OFFLINE
Dennisdeny
  • 3 posts
Posted October 27, 2011 - 08:29 AM
Thanks Guys. I took off the fender pan and found everything to look normal and turn freely. It appears the pump that drives the shaft has issues. Other than this the tractor operates normally. Was hoping for a simple fix.
#6 Dennisdeny OFFLINE
Dennisdeny
  • 3 posts
Posted November 02, 2011 - 12:00 PM
Ive been looking at the service manual i downloaded. Thanks Guys. It appars to me that the input shaft must be broken inside the housing as looks to be a single shaft. Anyone had one of these apart?
