B10 Grill
6 replies to this topic
#1 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted October 26, 2011 - 03:17 PM
I am looking for the chrome pieces that go on each side of the grill on a B10. Anyone have a spare set?
#2 KennyP ONLINE
  • 37,442 Thanks
  • 45,469 posts
Posted October 27, 2011 - 07:27 AM
:bump: Maybe some one will chime in on this.
#3 Dee OFFLINE
Dee
  • 53 Thanks
  • 68 posts
Posted November 01, 2011 - 01:19 PM
Saw these on ebay for a B110. May also fit the B10. check with the seller.
ALLIS CHALMERS B-110 CHROME GRILL PIECES | eBay
  • DanP said thank you
#4 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted November 08, 2011 - 08:44 PM
I checked in a parts manual and the chrome side pieces on the B-10 and the B-110 had different numbers. I also looked at pictures to be sure and they don't look like they have the same shape. Hope this helps.
#5 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted November 10, 2011 - 01:05 PM
Yes I found that out also. I may have to see if I can borrow a pair from someone to get them made and then have them chrome plated. There is a guy not to far from me that might let me use them. I tried to measure them but the angles would be easier to copy if I had a pair in my hands.
#6 B10Dave OFFLINE
B10Dave
  • 764 Thanks
  • 347 posts
Posted November 11, 2011 - 10:55 PM
Dan; if you are going to get a pair bent up I would recommend stainless. No chrome cost involved and you should be able to find pieces large enough for your purpose at a metal shop. Ask around and see if you can find a plant that does stamping of stainless parts and see if some of their scrap pieces would work for you. Good luck with your project. Dave.
#7 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted November 17, 2011 - 09:25 PM
[attachment=20946:20675.attach]
Dan,
I have these, and I believe this is the type you're looking for, as these are off a 1967 Allis B-10. As you can see, they aren't the best, even though the right mount cleaned up pretty well. I haven't tried to clean up the left mount yet, but will see what I can do on Saturday when I have a little more time to put into it. Even if it doesn't clean up as nice as the right one did, you would still have an original set of hood supports, that would just need re-chromed. Let me know what you think. If you aren't interested in them, that's OK, and there will not be any hard feelings.
Troy
