D4-10 Restoration
34 replies to this topic
#16 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted October 27, 2011 - 02:17 PM
whats the tube called lol. im dumb
#17 grand OFFLINE
grand
  • 1,925 Thanks
  • 1,979 posts
Posted October 27, 2011 - 04:52 PM
If you are talking about the part numbered 113 in the diagram I would have just called it the air cleaner assembly, but if you go to page 9 of the parts manual their name for it is air cleaner bracket assembly. I am certainly not the most informed person so hopefully one of the more mechanical folks can help better.
#18 olcowhand OFFLINE
  • 38,044 Thanks
  • 30,451 posts
Posted October 27, 2011 - 05:46 PM
I would likely call it the air filter manifold, but that's just me.
#19 KennyP ONLINE
  • 34,237 Thanks
  • 43,358 posts
Posted October 27, 2011 - 05:54 PM
I need to learn a bit about these 'Hogs'. I think I'll just lurk and learn. Good luck with it.
#20 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted October 28, 2011 - 11:06 AM
does anybody know how to pull start this motor if it is possible. any help is greatly appreciated
#21 olcowhand OFFLINE
  • 38,044 Thanks
  • 30,451 posts
Posted October 28, 2011 - 11:19 AM
Remove the electric start drive belt. The starter belt pulley on the engine should have a notch for a starter rope to hook into. Just a little trickier getting a rope wrapped with the pto system blocking a simple wrap around.
  • mixedbreed96 said thank you
#22 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted October 31, 2011 - 08:53 AM
So, got some snow over the weekend and decided to take the bush hog out.... BAD IDEA. Although it does great in snow, i pulled the throttle out going up our small hill and i can hear and feel something tapping next to my brake pedal. also, it shifted fine and now it wont go into gear and when it does the brakes dont work and pressing the clutch in doesnt disengage it. pulled off the seat and everything to check the trans axle fluids, looks like someone poured chocolate milk in it. it is really thick brown water looking stuff filled up to about half way. can anybody tell me how to drain and change this? and what might be wrong with the tapping and shifting issues? looking to change all the fluids in it this week before we get anymore snow
#23 olcowhand OFFLINE
  • 38,044 Thanks
  • 30,451 posts
Posted October 31, 2011 - 09:00 AM
The rear axle drain plug under the diff also drains the transmission. 89/90 gear oil is what to put back into her. Let it drain at least 24hrs, as the thick stuff will be very slow to come out.
As to the other issues, that is hard to guess. The clutch not working could simply be the clutch disc stuck/frozen to the pressure plate. Brakes not working maybe just because the engine with stuck clutch just overpowers it. The tapping might also be something in the clutch that came apart.
Maybe placing a heater to warm the clutch to see if it's frozen. Simple rust can stick the clutch disc also.
#24 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted October 31, 2011 - 09:06 AM
thanks olcowhand! ill try that today and let you know how i make out! im definantly not making out too well with this project (:
#25 JDBrian OFFLINE
  • 9,596 Thanks
Posted October 31, 2011 - 10:12 AM
Hang in there 96. It's all a learning process.
#26 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted October 31, 2011 - 06:31 PM
well drained the fluid and took the panel off next to the brake pedal and every single bolt and nut was missing from what i believe is the clutch disk? fixed that now just waiting for my new oil and ill be all set! any tips for making it quiter while running? im sure the neighbors love me when i run it
#27 olcowhand OFFLINE
  • 38,044 Thanks
  • 30,451 posts
Posted October 31, 2011 - 06:38 PM
I figure it's got a "pepper pot" muffler? They're not the quietest when new, but when they come apart inside, they are just rude loud! New muffler is all you can do.
#28 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted November 01, 2011 - 09:31 AM
i kind of want to put a stack on it
#29 olcowhand OFFLINE
  • 38,044 Thanks
  • 30,451 posts
Posted November 01, 2011 - 10:28 AM
I won't fault you no matter what you put on it. It's your tractor! A stack almost always look good!
#30 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted November 01, 2011 - 08:34 PM
Agreed! (:
