Sorry i got side tracked and forgot but i just did it.The rods on one of mine are 3/4 x 3/4 with a lenght of 16 1/8 inches long.The holes are drilled on center from one in is first hole 1/2 inch next hole is 8 inches these are the same size as the bolts used to moun the engine.The nest hole is 12 1/2 and the last hole is 15 5/8 and theses two holes are just 1/4 in dia.Both rods are the same.
As for the plate that the cylinder mounts two it is a 1/8 thick plate 5 1/8 wide.the plate is 10 3/4 long with a 90 degree bend 9 inches over.The holes are drilled at 3/8 and 6 3/16 on center for mouting on the tubes.The cylinder mounts on the side of the plate that has been bent at 5/8 .Make sure that the bend in the cylinder plate is point down and the cylinder hole will be towards the moto side of the plate.
If you have any questions on the dims just pm me you phone number and i will call you as i am not the best at typing this stuff out.
hydro lift
Started by
Guest_jdecker94_*
, Oct 23, 2011 07:20 PM
32 replies to this topic
#31
OFFLINE
Posted November 06, 2011 - 03:46 PM
- Bolens 1000 and MH81 have said thanks
#32
OFFLINE
Posted November 07, 2011 - 08:17 PM
Thanks for the info,I should be able to make what I need now
#33
OFFLINE
Posted April 11, 2012 - 03:13 PM
Does anyone know the psi and gpm for the hydraulic pump and what rpm the pump runs at?
