hydro lift
32 replies to this topic
#16 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted October 28, 2011 - 08:04 PM
does it have the big plate that mounts the cylinder? As for the rods they can be made i will need to measure one and get the mounting holes dims for you.The rods are just 1 x 1 cold roll steel rods
Edited by bhts, October 28, 2011 - 08:18 PM.
#17 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 28, 2011 - 08:42 PM
Here's a pic of a complete assembly
minus the plate that attaches to the transmission cover:h1.jpg
#18 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 28, 2011 - 09:09 PM
no square rods included. i couldnt take the motor off and get the rods, i had like 30 mins to get it off the tractor, get the tractor and everything loaded and reassemble the snowblower lol. some flat steel should be suitable.
#19 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted October 28, 2011 - 09:41 PM
No just any flat steel will not work as these were made to take place of the spacers.If you were to use just any flat steel then all the belts would not fit.
#20 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted October 28, 2011 - 09:46 PM
Umm,there are no square rods to mount under the motor
As long as you have the mount for the cylinder the rods can bee made.I belive i may have a set but if not i can measure them for you and send the mearsurments to you or canmake a set for you.If you don't have the plate for the cylinder i know i have one of those if you need it.
#21 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted October 28, 2011 - 09:51 PM
Mounting the Lift is fairly easy. You will need to remove the drive belts to get the hydro belt put on.
These pictures may be of some help to you
If you don't want to go to the trouble of removing the belts, you can do what I did with my G10, and use one of these:
High Performance Composite Belting - PowerTwist Plus, NuTLink and SuperTLink - Fenner Drives
They aren't cheap, but the time and effort that it will save you will make it worth it.
#22 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 28, 2011 - 10:04 PM
the belts arent hard to take off, and i believe the belt was a bolens brand so it does add originality points.
#23 Macgyver OFFLINE
Macgyver
  • 31 Thanks
  • 78 posts
Posted October 29, 2011 - 07:25 AM
So it looks like I need a few more pieces.I was under the impression the lift cylinder bolted to the frame,guess I need that mounting plate too.
#24 Macgyver OFFLINE
Macgyver
  • 31 Thanks
  • 78 posts
Posted October 29, 2011 - 07:28 AM
Hey Buzz I see from your pic that you only have 2 belts and that setup looks great.I have 4 belts,I assume I need to take 1 off and replace with pump belt once I get it mounted?
#25 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 29, 2011 - 07:30 AM
not really, take the 2 drive belts off, then you kinda weasel the pump belt over the spindles and there like a little slot it goes into.
#26 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted October 29, 2011 - 07:36 AM
More info here:
Hydrolic lift (old style) - Manuals - Garden Tractor Talk - Forums
Hydrolic lift kit newer Model - Manuals - Garden Tractor Talk - Forums
#27 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted October 29, 2011 - 07:56 AM
The picture oldbuzzard is using is off a G10 which only used a single belt for both the high and low range.
The hydrailic lift uses its own pulley groove.
On yours you should have 2 matched pairs of drivebelts that you will have to remove from the engine pulley to slip the hydraulic belt on.
  • Macgyver said thank you
#28 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted October 29, 2011 - 08:48 AM
The G10 is a bit different that the other tube frames. It doesn't have the same drive train. Instead of a clutch, it just uses belt tension. Changing the belts on a G10 is a pretty simple affair. It's NOTHING like the 'standard' tube frames.
If I would have had an earlier G10 I wouldn't have had to use the link belt. But, with the B&S engine, the throttle and choke cable is RIGHT where the belt would have to go. It was either disconnect the choke/throttle, install the belt, re-connect the choke/throttle, or use the link belt and just wrap it around the choke/throttle. The latter, while a bit more expensive, was a LOT easier and faster.
With the earlier G10 it's just a simple matter of removing the single drive belt, installing the hydro belt, and then reinstalling the drive belt.
With the 'standard' tube frames, the "Good Doctor" explains it quite well here:
http://gardentractor...n-tractor-1656/
Edited by OldBuzzard, October 29, 2011 - 08:54 AM.
#29 Macgyver OFFLINE
Macgyver
  • 31 Thanks
  • 78 posts
Posted October 29, 2011 - 03:23 PM
Thanks for the pics and info on the belts.now all I need to do is get the other parts I need to mount it.The tractor shop up the road from me used to sell Bolens in the 70s,but really has nothing left and not really interested in looking through their NOS for me
#30 Macgyver ONLINE
Macgyver
  • 31 Thanks
  • 78 posts
Posted November 06, 2011 - 02:14 PM
bhts,were you able to see if you had the plate and rods I need? or maybe the dimensions so I can make them myself.I was hoping to have this on the tractor already.
