Used Lathe & Mill Today
16 replies to this topic
#1 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted October 23, 2011 - 04:18 PM
Had to machine a part the other day & enjoyed it, as I'd not done any machining for a while. So today I built my driveshaft adapter to connect shaft on my MF1855 loader tractor to the Yanmar diesel I plan to put into it. So cranked up the South Bend lathe & Cincy end mill.
I started with this piece of steel:
And ended with this:
The recessed areas are for the bolts that attach the adapter to the Yanmar front pulley. This pulley just had 2 threaded holes for a puller, so I had to drill & tap 2 more holes for solid connection. The raised tapped holes is where the MF14 driveshaft I will be using will bolt to. The raised ring on top is the centering ring to perfectly align the driveshaft.
  • mikebramel and brokenfeather have said thanks
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 23, 2011 - 04:48 PM
Daniel, that adapter looks great, but it also looks like the same bolt circle almost. Was the adapter needed for bolt circle change, engine mounting position, or both?
#3 Bolens 1000 OFFLINE
  • 14,902 Thanks
  • 18,100 posts
Posted October 23, 2011 - 05:49 PM
Looks great Daniel :thumbs:
#4 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted October 23, 2011 - 07:06 PM
Casey, the bolt pattern is nearly identical...within thousandths. But the main thing was that there was no groove in the pulley to machine a centering section into the backside of the adapter. So I had to center as best I could, then bolted the adapter onto the pulley by the recessed spots, then chucked the pulley to the lathe to get a true center raised ring for the driveshaft. Without the recess, the bolt heads would have prevented me from machining the end.
  • wvbuzzmaster said thank you
#5 Cvans ONLINE
  • 6,455 Thanks
  • 6,052 posts
Posted October 23, 2011 - 07:18 PM
Nice work Daniel. I haven't had an opportunity my mill yet but the larger lathe should be a real plus on the next project as it seems to work great.
Just curious, Are you going to call it the Yanny-Ferguson?
#6 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted October 23, 2011 - 07:27 PM
No change in the name....she's just a worker!
#7 Alc OFFLINE
  • 6,741 Thanks
  • 7,395 posts
Posted October 23, 2011 - 07:37 PM
Very nice job ! Al
#8 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted October 23, 2011 - 08:14 PM
Dats good looking machining there by golly.
#9 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted October 23, 2011 - 08:49 PM
You did that. Nice job. Keep Milking them cows I can't lose my favorite drink. LOL
#10 Fabman OFFLINE
Fabman
  • 257 Thanks
  • 374 posts
Posted October 23, 2011 - 09:32 PM
Nice looking work there Daniel. Its been a while since i'v been on a lathe or mill. Lucky you on having your own.
#11 Lovintractorin OFFLINE
Lovintractorin
    Tinkerer
  • 159 Thanks
  • 603 posts
Posted October 24, 2011 - 05:49 AM
Someday I hope to get some of the fancy tools you guys have. Nice work, olcowhand.
#12 mjodrey OFFLINE
Posted October 24, 2011 - 06:51 AM
Good job Daniel. I plan to get a milling machine some day my self.
#13 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted October 24, 2011 - 07:40 AM
Nice work Daniel.
And you saved yourself a lot of money as well.
#14 caseguy OFFLINE
  • 1,627 Thanks
Posted October 24, 2011 - 04:12 PM
Great job Dan! Did you have any "formal" training or are you self taught?...Either way, it looks awesome to me!
#15 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted October 24, 2011 - 04:15 PM
Learn as I go.....you know....by making mistakes! LOL Never had training on anything. I've always taken pride in being able to do "most" anything I need to do. Not always pretty, but gets the job done.
  • tractorman604 said thank you
