3 point geometry question (CAT 0)
21 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 22, 2011 - 11:46 PM
I have a question for those with Category 0 three point hitches. I am going to make a sleeve hitch to CAT 0 adapter for the Caterpillar and will have a solid top link most likely. I plan to only lift/lower a homemade tiller, and trailer toter setup on the 3 point. For plowing and discing I will use my sleeve hitch stuff, so I need zero adjustment in my top link. The question is, what is the measurement of the top link location from the pivot of the bottom pins on the CAT 0 implements??
#2 engine2 OFFLINE
engine2
  • 5 Thanks
  • 1 posts
Posted October 23, 2011 - 04:47 AM
Should be 18" the same as Cat 1
  • DH1, wvbuzzmaster, Rozwell Ranch and 2 others have said thanks
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted October 23, 2011 - 07:23 AM
Just one caution on the diagram above. IME even some cat 1 implements are not fully 18" high. The compact implements built for small tractors with limited cat 1 for instance. I just measured a worksaver 24" cat 1 dirt scoop that I used on my jd x475, which was a limited cat 1. It is about 14" high from the top pin to the lift pins. Perhaps someone with a cat 0 implement could measure it as well. 18" just sounds too high to me.
  • wvbuzzmaster said thank you
#4 KennyP ONLINE
  • 38,356 Thanks
  • 45,925 posts
Posted October 23, 2011 - 09:18 AM
Brian, I was thinking the same thing. The top link on a GT isn't usually that long nor positioned very high above the lower arms. I may have something on a Cat 0 to sleeve hitch adapter. I'll look around and post what I find. Something to do.
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 23, 2011 - 09:21 AM
Those dimensions are great, it gets me a close enough set of numbers to determine if my plan will even work. I am really just trying to get it to a standard in case I want to buy new 3 point stuff that I don't build myself.
#6 KennyP ONLINE
  • 38,356 Thanks
  • 45,925 posts
Posted October 23, 2011 - 09:27 AM
I found this. It may be of some help.
I have a few more things stashed away on this puter, but this is the first I found with dimensions.
  • Alc, wvbuzzmaster, Rozwell Ranch and 1 other said thanks
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 23, 2011 - 10:15 AM
Anything can help Kenny, and you can't have too much information, well, ok, mabey with some things LOL.
#8 cityboy2977 OFFLINE
cityboy2977
    ordinary average guy
  • 117 Thanks
  • 179 posts
Posted October 24, 2011 - 08:25 PM
[ATTACH=CONFIG]23575[/ATTACH]
these are the dimensions i use for 3pt's i have made.
  • wvbuzzmaster, KennyP and BiGDaWgZ have said thanks
#9 KennyP ONLINE
  • 38,356 Thanks
  • 45,925 posts
Posted October 25, 2011 - 05:47 AM
Here's another with dimensions.
Not sure what else I may have.
#10 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 25, 2011 - 06:49 AM
This might be helpfull. Hope it's clear enough. I think I posted this in manuals, but I can't find it.
#11 KennyP ONLINE
  • 38,356 Thanks
  • 45,925 posts
Posted October 25, 2011 - 07:04 AM
Will, I have that also. Darned hard to figure anything out for me, must be the metric measurements.:bigrofl: Never been able to get those going right in my mind.
#12 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 25, 2011 - 07:25 AM
Yes Kenny, if you're not using metric all the time, it's a stumper.
Back to the original question, I make out the mast height to be 12" max from that info.
#13 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 25, 2011 - 07:31 AM
Here is the link to the pdf.
Not sure why I posted it in MF implements, but maybe someone could move it to a better place.
Cat 0 3pt hitch specs - Manuals - Garden Tractor Talk - Forums
#14 KennyP ONLINE
  • 38,356 Thanks
  • 45,925 posts
Posted October 25, 2011 - 07:52 AM
Will, where I get confused is what number you use to convert metric to inches. Most things have both inches/metrics shown. Guess I need to bookmark a site to do the conversion, but that doesn't help when I'm at the shop and the smart machine is in the house.
#15 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted October 25, 2011 - 11:18 AM
Most cell phones have an SAE to metric convertion feature in the tools menu.
