Use new or save the old
16 replies to this topic
Poll: Keep original bolts? (20 member(s) have cast votes)
  1. Try to save original bolts (2 votes [10.00%] - View)
    Percentage of vote: 10.00%
  2. Voted Replace with new (14 votes [70.00%] - View)
    Percentage of vote: 70.00%
  3. Other: please explain (4 votes [20.00%] - View)
    Percentage of vote: 20.00%
Vote Guests cannot vote
#1 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 21, 2011 - 05:17 PM
It's hard to talk GT's when Kenny is going through what he is.
I spent all day blasting and priming the rest of the parts to get ready for paint. I will place an order with Jestin to get her back to where she should be. I would like to know if it would be a negative to replace all the nut's and bolts with new ones.(ni-locks and such) It has a lot of cross breading of nut's and bolts, I just don't have time to try to keep what is there? Please feel free to voice your opinion about this.
Edited by MH81, October 21, 2011 - 07:12 PM.
#2 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted October 21, 2011 - 05:40 PM
After the last two rounds of implement reassembly with Orig bolts, I would advise to replace with new unless they are special or unique and visible. The plow really fought me during reassembly and I almost did replace them, but the share bolts were 7/16 coarse. A size I don't have a lot of, let alone plow bolts... If I'd only known...
BTW, I added a poll to this, and, as it sounds as you are planning on doing this soon, I capped it at 10 days.
Edited by MH81, October 21, 2011 - 05:45 PM.
#3 KennyP ONLINE
  • 53212 Thanks
  • 53322 posts
Posted October 21, 2011 - 05:59 PM
awol, thank you. But I don't expect the world to stop until this is over. The updates allow me to let go and share with all of you. And you have not in any way offended me. I am very thankful to know all of you are here.
Now, on the bolts. If you feel new is needed, go for it. It might be nice to use the original, but sometimes it's just not feasible.
#4 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted October 21, 2011 - 06:45 PM
I've replaced a lot of mine with new.
I'm a BIG fan of the Ny-Loc nuts as well. They are SO much better than lock washers.
One thing to remember is that bolts stretch, and if you tighten them too many time the don't stay snug.
  • awol said thank you
#5 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted October 21, 2011 - 07:03 PM
[quote name='BTW, I added a poll to this, and, as it sounds as you are planning on doing this soon, I capped it at 10 days.[/QUOTE']
I did not know that there was a poll on this!!! 10 days seems a little quick.IMHO
#6 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted October 21, 2011 - 07:40 PM
Lets see , I replace bolts and nuts , when I break them , torch or cut them , but mostly when I lose them, really , Al
:bigrofl:
#7 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 21, 2011 - 07:44 PM
I usually replace the nuts and bolts when I restore my Bolens.
#8 caseguy OFFLINE
  • 1635 Thanks
  • 5600 posts
Posted October 21, 2011 - 08:30 PM
Like many have already said, I generally use the original bolts if they are servicable, but I have no qualms about replacing them if need be.
#9 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted October 21, 2011 - 08:33 PM
Ok, I made it 20 LOL.
#10 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3484 Thanks
  • 2816 posts
Posted October 22, 2011 - 12:27 AM
well if your tractor has a special length bolt, or in the case of a cub, that has ih stamped in the head, then you probally could just use what you wanted. Some tractors like the DB use some odd length bolts, all the handimans use the sq headed ones. Ive never notice whats on a Bolens.
Plow bolts are easy to get a almost any farm store, if there to long just run the nut down and saw them off. I hardly ever reuse them.
#11 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted October 22, 2011 - 04:17 AM
I will save old bolts only when they are in good shape.Otherwise I replace,bolts aren't that expensive.
#12 EricFromPa ONLINE
EricFromPa
    Fixer of Broken junk
  • 6892 Thanks
  • 4615 posts
Posted October 22, 2011 - 04:43 AM
Voted go with New bolts and nuts.
Just because EVERY used tractor I've ever owned has had atleast a couple (some had dozens) of stubborn rusted,pitted and just plain old Worn out bolts in them that made restoration or fixing them a PITA.
I put Stainless bolts and Stainless Ny-Lock nuts everywhere that's visible and every place that will come in contact with Grass,dirt or water such as Deck spindle bolts.
There are still a few places around that sell nuts and bolts by the pound.
#13 grand OFFLINE
grand
  • 2309 Thanks
  • 2074 posts
Posted October 22, 2011 - 05:50 AM
We have bought nuts and bolts at TSC. I'm sure that most folks know that they sell them by the pound which makes them inexpensive. It is so much easier to work with new bolts.Like Lauber1 said if you have a specially stamped bolt it would be great to save. As for length, if it fits and is too long,the rascal just gets cut.
#14 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted October 22, 2011 - 06:38 AM
I generally replace them when they are standard items. Make sure you use the correct grade of bolt. I try to save bolts with manu. markings, like the bolts with MF stamped on the head on my 8. It can end up costing a lot for hardware. I tend to go to a local store that has really good prices and buy a stock of common length of 1/4, 5/16 and 3/8 bolts nuts etc. That way I can replace them on the fly.
  • Lauber1 said thank you
#15 KennyP ONLINE
  • 53212 Thanks
  • 53322 posts
Posted October 22, 2011 - 07:18 AM
I went with the 'other' option. If the bolt is not 'standard', it's hard to find replacement. If it is a normal, I will use new or a 'better condition'.
