Are implements complete for GT16 ?
38 replies to this topic
#16 Laseman OFFLINE
Laseman
  • 20 posts
Posted October 22, 2011 - 04:23 AM
Hi
Thanks for your help and advice to get possible parts for "unversal shaft",
but problem is that I live 4000 miles away from you, I live in Europe.
When someone have time, is it possible to get more details of measurement of "unversal shaft" see picture, so I can search for similar parts around here.
#17 ford boy OFFLINE
ford boy
  • 21 Thanks
  • 87 posts
Posted October 22, 2011 - 10:13 AM
i will grab those measurements later today and post them tonight , just to clearify you would like the measurement of the gearbox aswell as the other measurements right?
#18 ford boy OFFLINE
ford boy
  • 21 Thanks
  • 87 posts
Posted October 22, 2011 - 02:32 PM
ok heres the measurements as follows , A is 4 3/4'' , B is 8 1/2'' , C 4 3/4'' , D 2 1/4'' , E 3/4'' , F 1 1/2'' , G 3'' , by the way A on your diagram i measure from that step by u joint that you indicated in the photo straight to the blower houseing like your diagram is set up is 4 3/4'' , for just from the step by the u joint to the very end of where you pin the joint to shaft on the blower is 3 3/4''
#19 Laseman OFFLINE
Laseman
  • 20 posts
Posted October 28, 2011 - 01:58 PM
Hi and thanks for your measurements and help.
I looking around for this "unversal shaft" and ask other tractor owner how to find it.
I wounder little about inner and outer diameter at the end of pipes for "unversal shaft", see letter A and B in picture.
Best regards / Lasse
#20 ford boy OFFLINE
ford boy
  • 21 Thanks
  • 87 posts
Posted October 28, 2011 - 05:38 PM
i will take a look tomorrow and take down thoses measurements and get back to you , by the way i don't know how much the shaft would be , but i think its still availble from www.messicks.com yet i don't know if they would ship to Europe
#21 Laseman OFFLINE
Laseman
  • 20 posts
Posted October 30, 2011 - 01:21 AM
Hi
Is it possible to use Shaft from Jacobsen Tiller on the Jacobsen Snow Thrower ?
The Tiller is complete and owner have used it some times.
It should be same pipe connections.
But is it same lenght ?
#22 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted October 30, 2011 - 05:28 AM
Do you by chance have the model #s of the tiller and snow blower handy? If so, we can look up the part #'s for the shaft on each and see if they match. If so, then it should work.
I looked up the part#s for the 09jc9734 tiller drive shaft:
If we get the snow blower model #, we can check those part #'s against these.
Edited by KennyP, October 30, 2011 - 05:51 AM.
#23 Laseman OFFLINE
Laseman
  • 20 posts
Posted October 30, 2011 - 07:39 AM
The owner sent more pictures with Snow Thrower Shaft part, so I think also Snow Thrower is complete.
He has been abroad a week and he lives 340 miles away.
In picture, Shaft part (male) is connected to Snow Thrower
As I understand, the "unversal shaft" consists of 2 parts, (female part and male part)
A = Shaft part to Gear Box (female part)
B = Tiller Shaft part (male part)
C = Snow Thrower Shaft part (male part)
Thanks very much for all your help and pictures etc....
Jacobsen with implements is maybee complete, so I can purchase it.
#24 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted October 30, 2011 - 07:48 AM
So you use the same female part for both the tiller and the snow blower? Sounds like that would fix you right up.
#25 Laseman OFFLINE
Laseman
  • 20 posts
Posted October 30, 2011 - 12:44 PM
Well, "ford boy" sent picture with FRAME on Snow Blower to attach on Tractor.
See picture below.
I do not find this frame and spring on any picture I get from owner, maybee I should ask him about this also.
#26 Laseman OFFLINE
Laseman
  • 20 posts
Posted October 31, 2011 - 04:16 AM
Missing Part ?
Is this a standard Jacobsen GT "Lift Arm"
I found pictures on internet
As I understand, this "Lift Arm" is important for both SnowBlower and Snowplow,
and it seem this owner do not have them.
What do you say, Jacobsen GT owners ?
#27 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted October 31, 2011 - 05:35 AM
The blade you show at the top of this thread is different than the one you just posted, so I can't really say. And I really don't have a clue on snow blowers. Without model #'s on these attachments, I can't help you. Maybe someone more familiar with these can let us both know.
#28 ford boy OFFLINE
ford boy
  • 21 Thanks
  • 87 posts
Posted October 31, 2011 - 07:26 PM
well to start with the plow blade that you show a photo of at the top of the 1st page mounts to the front of the frame and all the parts you need are there , it was a economy version means that there is no mounting arm that you where talking about , where the one you show in post 26 is the true dozer blade which has that arm assembly that slides under and mounts to the tractor its a little more heavy duty then the economy blade , i will take a look at your first posted pics and check , but i think that arm assembly for the blower like the one in post 26 should on the tractor
#29 ford boy OFFLINE
ford boy
  • 21 Thanks
  • 87 posts
Posted October 31, 2011 - 08:00 PM
Missing Part ?
sorry i was wrong the lift arm like the one thats attached to the blower in this upper right photo is not in any of your pictures , you might ask the owner you never know maybe he forgot about it and has it stored away , the lift arm attachs to the frame assembly with the gear box on it thats mounted on the front of the tractor then all that attachs to a bracket mid frame mounted of the tractor , then the frame assembly with the lift arm attached , attachs to the blower houseing with a couple bolts and has the two springs to work as a trip sort of setup , i will take a picture of the whole shabang tomorrow to show you whats needed and how it all goes togather
#30 Laseman OFFLINE
Laseman
  • 20 posts
Posted November 01, 2011 - 04:03 AM
Hi "ford boy"
Yae, I would appreciate pictures how "Liftarm" is placed into implement and under minitractor.
Well, the owner has not seen this "Liftarm", that is boring......
