What is my transmission?
3 replies to this topic
#1 kevinb0906 OFFLINE
kevinb0906
  • 1 posts
Posted October 18, 2011 - 10:31 PM
What a great site! I have an early 1970's Hahn lawn tractor built in Evansville, Indiana. The gear oil leaks out the axle tube on both sides of the transmission. My old 1975 Massey 12G had the same issue so I know it is common with these old lawn tractors. I know the Massey had a Peerless trans but I have NO clue what trans my Hahn has. Please help, I want to get her leak free!! :smile1:
#2 Bolens 1000 ONLINE
  • 15,291 Thanks
  • 18,235 posts
Posted October 19, 2011 - 05:00 AM
Welcome to GTT! :wave:
I cant answer your question but hopefully someone else will.
It may help if you post a couple of pictures of the tractor/ transmission
#3 mjodrey OFFLINE
Posted October 19, 2011 - 05:07 AM
Welcome to the forum.
Glad to have you with us.
I can't answer your question either,but I sure someone will be along that can.
#4 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,943 Thanks
  • 2,460 posts
Posted October 19, 2011 - 12:47 PM
What model and series is your tractor? ......I have some Hahn-Eclipse manuals, and may have some info.
However, oil seals can be purchased through many mower shops, auto parts, bearing supply houses and power transmission specialists. .....If you have an old seal, new seals can often be matched by size or by numbers (which may be) on the seals.
If a seal leaks, it may be caused by a worn shaft, a worn bearing/bushing, or an old, tired seal.
