Fuel filters
6 replies to this topic
#1 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted October 18, 2011 - 08:04 PM
When I was at a flea market over the weekend a fellow had a stand for new small engine parts , I was looking at inline fuel filters and two looked the same but one was white and the other red, I asked "whats the difference ?" he said the red one was for without fuel pumps ( gravity feed ) and the other when you had a fuel pump ( pressure side) I started thinking that the fuel filter I installed on the DB wasn't the correct one and that maybe the running problem I was having :wallbanging: Even on the JD 318 it has a fuel pump but the filter is on the suction side , could that be my long cranking problem, wrong filter installed :wallbanging:
  • grand, MH81, Texas Deere and Horse and 1 other said thanks
  • 14,810 Thanks
  • 15,499 posts
Posted October 18, 2011 - 08:10 PM
I bet thats why my 317 starts so hard. I have to chock it forever. Thanks Al.....
#3 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted October 18, 2011 - 08:24 PM
I think the ones For the fuel pump have a finer screen than the gravity filters.
#4 grand OFFLINE
grand
  • 2,042 Thanks
  • 2,014 posts
Posted October 18, 2011 - 08:25 PM
Thanks Al for some very useful information.
#5 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted October 18, 2011 - 08:41 PM
:ditto: Right you are.
RED - 150 micron for use on gravity feed.
WHITE - 75 micron for use with fuel pump.
both 1/4" line.
> Small Engine Fuel Filters
  • ducky said thank you
#6 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted November 24, 2011 - 10:50 PM
thanks Alc
got the red filter to go on my 110, been need one. and got the larger white filter for the 212 and 214 - had plugged screens in the tanks and use the air compressor to blow the line out because the 35+ years the screens were bad. should had clean fuel to the carb now
#7 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted November 25, 2011 - 05:55 AM
Most of the commercial equipment with either pulse or electrical fuel pumps I have worked on have a fuel filter between the tank and pump just to keep the garbage out of the pump. Many of the gaoline fueled machines also have a second, and finer, filter after the pump. Many of the diesel fueled machines have a fuel/water separator between the fuel pump and injection pump.
