Rusty Gas Tanks
13 replies to this topic
#1 Ellitott OFFLINE
Ellitott
  • 1 posts
Posted May 03, 2010 - 05:14 PM
Rusty Tanks I have one on an Montgomery Wards garden tractor. Any CLEAN solutions would be helpful
#2 Bolens 1000 ONLINE
  • 15,298 Thanks
  • 18,236 posts
Posted May 03, 2010 - 05:28 PM
Usually some small pebbles with some water or solvent will do the trick.
Just drop some pebbles in shake it dump it out put them back in with some Water or some type of cleaner and repeat until clean.
mabye others may have a better idea.....
Welcome to GTtalk by the way :thumbs::welcometogttalk:
#3 poncho62 ONLINE
poncho62
  • 1,996 Thanks
  • 1,744 posts
Posted May 03, 2010 - 05:44 PM
I was told to use a hand full of drywall screws, but I guess lots of things will work.......I have a rusty one too.....with a few pinholes also....Looking for an epoxy sealant to fix it.
#4 mjodrey OFFLINE
Posted May 03, 2010 - 05:45 PM
:ditto:Or small steel ball bearings.
:welcometogttalk:,glad to have you here.
#5 olcowhand ONLINE
  • 42,453 Thanks
  • 31,824 posts
Posted May 03, 2010 - 05:48 PM
I just use gravel & diesel fuel. Strap that tank inside a tractor wheel, the drive it a bit. Gives a good slow rolling action & no work to it.
#6 mjodrey OFFLINE
Posted May 03, 2010 - 05:55 PM
I use my paint shaker,it works good too.
#7 olcowhand ONLINE
  • 42,453 Thanks
  • 31,824 posts
Posted May 03, 2010 - 06:04 PM
I should say it would! Not many of us have paint shakers though I'm afraid. I could however strap it to my little chihuahua, then go out & shoot a gun. When he hears a gun, he trembles like an earthquake! I got him grown, so I figure he collected some buckshot at one time or another.
#8 mjodrey OFFLINE
Posted May 03, 2010 - 06:28 PM
That would make an interesting video :bigrofl: with a gas tank strapped to him and all that trembling.
#9 Bolens 1000 ONLINE
  • 15,298 Thanks
  • 18,236 posts
Posted May 03, 2010 - 06:57 PM
I will definietly remember that for next time.
#10 Rick OFFLINE
Rick
  • 15 Thanks
  • 168 posts
Posted May 04, 2010 - 03:15 PM
A good radiator shop should be able to cook it out for you.I had the tank on my case 446 cooked out,it turned out perfect.
#11 joe OFFLINE
joe
  • 2 Thanks
  • 24 posts
Posted May 09, 2010 - 11:12 AM
Wow James that a good one, I have use the Vinegar it works great the other one for this old man. mite be away to get them ground mole out of my yard or the whole block:booboo: "explosive hydrogen bomb":firejumper: for them little mole's Thanks for posting the info
#12 AcreFarm OFFLINE
AcreFarm
  • 110 Thanks
  • 359 posts
Posted May 09, 2010 - 11:40 AM
Now there's one to remember. I have always used a little diesel and a chain, or some nuts/bolts... whatever to get the loose stuff out, then vinegar to finish. Strapping it to a wheel would save allot of shaking, and add seat time too :smile1:
#13 C Holmes OFFLINE
C Holmes
  • 12 posts
Posted May 12, 2010 - 05:25 AM
I done one by taking it apart at the seam. Just melted the solder, pulled it apart and cleaned inside with a wire brush and then re-soldered back together. That worked pretty good.
#14 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted May 12, 2010 - 05:47 AM
That's not a bad idea. I would be afraid I would never get it soldered back together correctly LOL
