engine and frame degreaser
11 replies to this topic
#1 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted October 18, 2011 - 03:35 PM
What do you think is the best product or homemade concoction for degreasing a garden tractor engine and frame from years of caked on soil and grease:anyone:
#2 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,129 posts
Posted October 18, 2011 - 04:25 PM
I used ,I think it's called deep purple made by castrol.You should be able to get it at any car parts store.Also a pressure washer.Be careful though i degreased my wheel horse on fathers day weekend,and still didn't get it running. No spark .Due to lack of time.
  • tractorman604 said thank you
#3 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted October 18, 2011 - 04:34 PM
Spray some Easy-Off Oven Cleaner on it, let set for above 10 minutes, then spray it with the pressure washer. Depending on how thick the grime and grease is, you may have to apply twice, but usually a good heavy, thick coating, gets right down to the block. After it's clean, wash it good with Dawn dishwashing liquid. For drying, blow it off good with air from an air compressor. You'll then be ready for primer and paint.
For hard to reach areas, say between cooling fins, spray on some Bug and Tar Remover, let stand fro 2-3 minutes, spray with full blast garden hose. Follow up with Dawn dishwashing liquid and air compressor.
  • tractorman604, MH81, Texas Deere and Horse and 7 others have said thanks
#4 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted October 18, 2011 - 04:46 PM
Those are great ideas JDelfman. Common cleaners that can be found easily at a reasonable cost. Thanks!
#5 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted October 19, 2011 - 02:06 PM
LA's totaly awsome, yellow degreser. you can find it at the dollar store and it works great. I go buy 10 bottles at a time and the people who work there think im crazy
  • tractorman604, MH81 and brokenfeather have said thanks
#6 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted October 19, 2011 - 03:26 PM
I use totally awesome as well....$3.00 per bottle and use it full strength for most the jobs I do. Dollar store.
#7 guglielmo69 OFFLINE
guglielmo69
  • 12 posts
Posted October 19, 2011 - 05:15 PM
I like simple green
#8 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted October 19, 2011 - 09:43 PM
+1 for simple gren.
Also, when we lived in Florida, used the "solar heated poor man's pressure washer" a lot - translation for you non-Floridians - We left a garden hose coiled up in the back yard in the sun. With a pressure nozzle, you had near boiling water coming out of it for a few minutes untill the hose flushed out......
#9 IamSherwood OFFLINE
  • 8,390 Thanks
Posted October 20, 2011 - 06:51 AM
Knights Engine degreaser seems to work well. Same company that makes Spray 9.
I found a 5 gallon pail under a bench at work that had been there for 20 years.
#10 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted October 20, 2011 - 07:56 AM
wow 3 bucks a bottle. I get the 32 oz refills for a buck were i live
  • brokenfeather said thank you
#11 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted October 20, 2011 - 10:26 AM
They charge $1.00 for the spray bottles (20 oz) and $3.00 for the refill bottles (64 oz) in my neck of the woods.
Interesting that they are selling different sizes in different areas....will check next time I am traveling in VA or SC.
#12 cityboy2977 OFFLINE
cityboy2977
    ordinary average guy
  • 117 Thanks
  • 179 posts
Posted October 20, 2011 - 02:56 PM
oven cleaner for 10-15min.
rinse repeat
