how nice are your garden tractor tires
25 replies to this topic
#16 AverageJoe OFFLINE
AverageJoe
  • 105 Thanks
  • 143 posts
Posted May 06, 2010 - 05:04 AM
My JD 318 has ags on the rear and tri-ribs on the front. For mowing, the tri-ribs are less than ideal as they have so much traction, they will cut damp ground. They do look good though.
#17 fonz3482 ONLINE
fonz3482
  • 1,314 Thanks
  • 782 posts
Posted May 07, 2010 - 06:20 AM
I bought gbc lumberjacks. I love them! Work awesome in all conditions and were very cheap compared to ags. Only thing with them is on pavement you cant make sharp u turns in high gear. The sidewalls are softer and flex making the tractor fell alittle tippy. Not an issue any other time just when on pavement making fast sharp u turns.
#18 Rick OFFLINE
Rick
  • 15 Thanks
  • 168 posts
Posted May 08, 2010 - 06:44 PM
Ribs on the front don't rip up the yard and they make your tractor steer easy.
#19 olcowhand ONLINE
  • 40,374 Thanks
  • 31,177 posts
Posted May 08, 2010 - 09:10 PM
They'll plow if you go fast enough! Maybe Drake has a lead-foot when he's on that John Deere! :rofl2:
#20 turbo OFFLINE
turbo
  • 14 posts
Posted May 13, 2010 - 12:11 AM
i just got my mud lights on i had to cut the runners but i keept them so i can weld then back on if i want to latter im adding pics of my new tyres asap
#21 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted October 23, 2013 - 11:15 PM
I have 6 ply trencher tires front & back loaded with rv antifreeze & wheel weights. Trencher tires have greater max load limits.
#22 OldBuzzard OFFLINE
OldBuzzard
  • 6,987 Thanks
  • 4,784 posts
Posted October 24, 2013 - 02:51 AM
Well, most of my herd have decent tires, some have new ones, and I have one that's definitely in need of new tires.
The HDT1000 has CST Ancla ATV tires on the rear and V61s on the front, all new.
A 1250 has a pair of almost new and a pair of new Carlisle R4 tires on the rear.  It could use new fronts.
1886 with FEL has CST Anclas on the rear, and Carlisle Turfs on the front, both new.  I'd like to have had v61s in it but they don't make them in 20x8x10.
My 1886 Forklift is definitely in need of new tires all around.  Not sure what's going to go on it yet.  The Ags on the rear are REALLY worn down, and the front's aren't far behind.  I'm actually amazed that they still hold air!  Odds are it will get Anclas and V61s like the HDT1000.
  • Justin2655 said thank you
#23 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted October 24, 2013 - 03:24 PM
Who all is running bigger than 16-6.5-8 on the fronts??
Right now my rears are 23x10.5x12 but I would like to go to 26x12x12 and the fronts I would like to step up to 18x?x8 maybe.
I want them to be AG tires all around.
#24 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 24, 2013 - 06:14 PM
I do not have pics on my iphone, but if one of the mods wishes to dig out a pic of my caterpillar they may. The rear tires are 26x10.50-12 Titan Mud Monsters and the fronts are 16x6.50-8 Snow Hogs.
#25 OldBuzzard OFFLINE
OldBuzzard
  • 6,987 Thanks
  • 4,784 posts
Posted October 24, 2013 - 07:53 PM
Who all is running bigger than 16-6.5-8 on the fronts?? ...
That 1886 with the FEL I listed above has 20x8x10 tires on it.
I'm almost thinking of using that tire/wheel combo in the Forklift and using the 27x9.5/15 tires/wheels from my other 1250 on it.  That would give me a little bit more ground clearance with it.
Here's a side view of the 1886 with the 20" fronts so you can see what it looks like.
#26 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted October 28, 2013 - 11:05 AM
Hmm, those don't look much different than 16's on the front, I think I will have to try that.
I already bought a set of 16x6.5x8 front AG tires but I can use them on my Allis 916H.
