1983 JD 318 with onan - oil drain plug?
10 replies to this topic
#1 K3522 OFFLINE
K3522
  • 7 Thanks
  • 21 posts
Posted October 17, 2011 - 06:49 PM
I looked in the holes through the frame on both side and no valve? I looked underneath and no drain? I took the side covers off and no drain? The oil filer is a NAPA 1348 but I did not take the engine sheild off to see if the drain was behind that. I bought the tractor in June but never asked where the oil drain is. maybe the owner before me removed a drain hose or valve?
#2 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,167 posts
Posted October 17, 2011 - 06:58 PM
The drain should be on the right side.There is a hole in the frame towards the front tire look in it and you should see a brass tee which should be the drain.
#3 K3522 OFFLINE
K3522
  • 7 Thanks
  • 21 posts
Posted October 17, 2011 - 07:02 PM
I looked in the hole near the front wheel on both sides and there is no brass valve. This is a 1st year 318 built in 1983. Maybe the oil filter is the drain? I looked at the manual on this site and I do not have a valve like is show being opened with plyers? Boy do I feel stupid!
Edited by K3522, October 17, 2011 - 07:13 PM.
#4 olcowhand ONLINE
  • 42,498 Thanks
  • 31,835 posts
Posted October 17, 2011 - 07:15 PM
Someone may have removed the drain valve for whatever reason & put in a plain pipe plug.
#5 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,167 posts
Posted October 17, 2011 - 07:28 PM
:ditto:
Look on the right side in the hole and see if you see a fitting with a square head on it.The oil filter will not drain the oil out just what is in the filter.
#6 K3522 OFFLINE
K3522
  • 7 Thanks
  • 21 posts
Posted October 17, 2011 - 07:33 PM
Nothing? I will take a picture tomorrow.
#7 olcowhand ONLINE
  • 42,498 Thanks
  • 31,835 posts
Posted October 17, 2011 - 07:48 PM
Could be that the oil pan has been replaced with one from another model Onan???? I know many will interchange. Look just below & to the side of the oil fill tube & see if there is a plug there.
#8 K3522 OFFLINE
K3522
  • 7 Thanks
  • 21 posts
Posted October 17, 2011 - 07:49 PM
Former owner just called. The 1983 JD 318 is the only year the oil drain plug is underneath the tractor near the mule drive. In fact he suggested I remove the mule drive to keep it and the belt from getting oily when changing the oil. Figures I have the one year model that has the drain in a weird location!
Thanks for the help.
#9 olcowhand ONLINE
  • 42,498 Thanks
  • 31,835 posts
Posted October 17, 2011 - 07:51 PM
Well I'll be. Never knew of that one. But I'm no JD guru either. Glad you found the answer.
#10 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,167 posts
Posted October 17, 2011 - 07:59 PM
Thats a new spot for me two lol.Glad you found the little bugger.
#11 KennyP OFFLINE
  • 40,236 Thanks
  • 46,811 posts
Posted October 18, 2011 - 04:16 AM
Woohoo! Mystery solved. Glad the PO let you know where it was.
