16" Wheel Weight Question
6 replies to this topic
#1 jrk OFFLINE
jrk
  • 42 Thanks
  • 95 posts
Posted October 16, 2011 - 09:47 PM
Quick Question Everyone -
Does anyone know of any other garden tractor weights that will fit on a 16" rear Power King or Case wheel? Maybe wheel weights off the front of a large tractor or Farmall Cub ???
Thanks in advance!
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted October 16, 2011 - 10:03 PM
ones from most DB walker will fit a 16" rim.
#3 Rozwell Ranch OFFLINE
Rozwell Ranch
  • 5 Thanks
  • 17 posts
Posted October 17, 2011 - 11:54 AM
Seems to me that some older vintage combines had 16' wheels and wheel weights.
Might be worth checking out some farm equipment salvage yards just to see what might be there....
  • caseguy said thank you
#4 Billygoat OFFLINE
Billygoat
  • 76 Thanks
  • 206 posts
Posted October 17, 2011 - 03:38 PM
It's my understanding front weights from Ford 2/8/9 N's will fit.
#5 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,800 Thanks
  • 5,097 posts
Posted October 17, 2011 - 04:24 PM
On my Power King 1614 I used Ford 6600 utility front wheel weights and they bolted up fine. They are the two piece kind so I put them on the inside so they don't stick outside of the path the snow blade cuts. Each section is 50# so it added 200 LBS to the back of the tractor. If you want to put them on the outside you would have to cut a small notch for the valve stem to clear. They are cast iron and have FoMoCo cast right into the weight.
TractorData.com Ford 6600 tractor information
#6 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted October 17, 2011 - 05:32 PM
That is true. The weights on member Joshbrown's Case 446 came off my old Massey 410 combine. They were sectional wights, so his just had the one inner portion of the weights on it. The whole 3 plates would be well over 200 lbs!
#7 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 17, 2011 - 05:47 PM
The Farmall Cub front wheel weights were designed for the rear wheels of Cub Cadets.
