Suggestions for skid shoe repair
9 replies to this topic
#1 Michiganmobileman OFFLINE
Posted October 16, 2011 - 07:23 AM
Hello to all GTTALKers.
My shoes are well worn and I do need to repair before the snow hits. Thought of just a piece of angle iron notched and bent then welded to what is left of the old shoe. But figured someone has "been there done that" before and was looking for suggestions, warnings, and or ideas.
Thanks in advance.
#2 KennyP ONLINE
  • 40,089 Thanks
  • 46,752 posts
Posted October 16, 2011 - 09:20 AM
I haven't a blower, but that sounds like something I might do on my blade skids. Just to give a bit more wear surface.
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 16, 2011 - 04:00 PM
I have never repaired snow shoes, but I would go with thick material to avoid having to repair them every year. I also have wondered about why they don't use some sort of tall narrow wheels instead of skids.
#4 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted October 17, 2011 - 10:48 AM
That is exactly what I used on my blower skids. Just be sure to give yourself a bit of a kick up in the back too or they may catch in reverse.....:confuse: Been there, had to fix that.
P.
#5 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted January 22, 2012 - 08:57 PM
If you repair the shoes then coat them with a hardface weld they will wear much slower.
#6 Michiganmobileman OFFLINE
Posted January 22, 2012 - 09:13 PM
Thanks for the suggestion!
Here is my after repair thread
http://gardentractor...y-blower-10469/
Have been in use for a few weeks now but I think I may do as you suggest next year, if nothing else that is a good excuse to practice welding.
Oh and I dont think I have said so yet so :welcometogttalk:
Edited by Michiganmobileman, January 22, 2012 - 09:52 PM.
#7 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted January 22, 2012 - 09:39 PM
I don't know how much of the original shoe you have left but if there is enough to hold a weld you could build upon that with a welder. Most welding buildup will be much harder than the original shoe material.
#8 Michiganmobileman OFFLINE
Posted January 22, 2012 - 09:52 PM
Click here Bill for the full post http://gardentractor...y-blower-10469/
This is what I started with
#9 kb0nly OFFLINE
kb0nly
  • 18 Thanks
  • 63 posts
Posted January 25, 2012 - 10:31 AM
Check out SnowBlowerSkids for a possible replacement also. I have a set of them on my Ariens and love them, just ordered a second set to go on my Craftsman as well.
#10 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted July 11, 2012 - 03:57 PM
Michiganmobileman...You could add a strip of UHMW on your newly rebuilt shoes then replace the UHMW when it wears out.
You can get it from UNITED STATES PLASTICS (Lima Ohio), GRAINGERS and McMASTER/CARR, as well as some local places.
For those that may not know what UHMW is:
http://en.wikipedia....ht_polyethylene
10" x 10" Plastic Prototypes Posted Image
Black Reprocessed UHMW Posted Image
Duravar UHMW-PE Polymer Bar Clip-On Extruded Profile Posted Image
Duravar UHMW-PE Polymer Bar Clip-On Round Top Extruded Profile Posted Image
Duravar UHMW-PE Polymer C-Rail Assembly Profile Posted Image
Duravar UHMW-PE Polymer C-Rail Assembly-Round Top Extruded Profile Posted Image
Duravar UHMW-PE Polymer C-Rail Cover Extruded Profile Posted Image
Duravar UHMW-PE Polymer C-Rail Cover-Round Top Extruded Profile Posted Image
Duravar UHMW-PE Polymer Full Round Snap-On Extruded Profile Posted Image
Duravar UHMW-PE Polymer Guide Rail Snap-On Extruded Profile Posted Image
Duravar UHMW-PE Polymer Half Round Snap-On Extruded Profile Posted Image
Duravar UHMW-PE Polymer Long Guide Rail Snap-On Extruded Profile Posted Image
Duravar UHMW-PE Polymer Small Guide Rail Snap-On Extruded Profile Posted Image
Duravar UHMW-PE Polymer Wide Guide Rail Snap-On Extruded Profile Posted Image
UHMW Board Stock Posted Image
UHMW Cut Sheet Posted Image
UHMW Dog Bone Shape Posted Image
UHMW Extruded Chain Guide Channels Posted Image
UHMW Full Sheet Posted Image
UHMW Polyethylene and Polypropylene L-Angle Posted Image
UHMW Rectangular Bar Posted Image
UHMW Round Rod Posted Image
UHMW Tubing
  • Michiganmobileman said thank you
