Things I recently learned.
11 replies to this topic
#1 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted May 02, 2010 - 10:11 PM
I believe in the old saying "you learn something new everyday". Somethings may be helpful, like how to get that stripped screw out, or somethings you learn may just be strange or interesting, like the girl you've been dating is really a man.
Here are a couple things I learned recently:
Peerless 2300 series transaxles are not indestructible.
One of my tractors thinks its part bucking bronco, part ballerina
Some chickens are curious, and it freaks me out.
Brinly moldboard plows work really good.... until you bend the sh*t out of them.
If you forget to change the polarity of your welder when switching from gas to gasless wire, you will begin to think you are the worst welder in the world.
If you have a 20 ton shop press, a 24" pipe wrench with a 3' pipe on the handle and a large vocabulary of swear words, you can straighten very bent/twisted metal.
mf650 tiller w/extension + tractor with turf tires and no weight added + slippery damp grass + fence = dirty underwear.
Have you learned anything interesting, helpful or strange lately?
#2 chopperfreak2k1 OFFLINE
chopperfreak2k1
  • 18 Thanks
  • 431 posts
Posted May 03, 2010 - 07:18 AM
i have learned NOT to mow through mud cuz it really ticks me off, unless i've been drinkin, then it's kinda cool.
#3 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted May 03, 2010 - 07:49 AM
I have learned that any restoration project you do will always take at least twice as long and cost at least twice as much as first thought. That must be why I don't have a time clock in my garage and I don't save the slips from parts and hardware stores!
#4 jff24gordn OFFLINE
jff24gordn
  • 4 posts
Posted August 19, 2010 - 07:02 PM
All of my local parts stores know not to give me a copy of the receipt.
#5 olcowhand OFFLINE
  • 42,460 Thanks
  • 31,824 posts
Posted August 19, 2010 - 07:09 PM
Broken2....tell us more about those "dates" you've been on!:bigrofl::bigrofl::bigrofl::bigrofl:
#6 caseguy OFFLINE
  • 1,629 Thanks
Posted August 19, 2010 - 07:27 PM
I've learned that the things you put off till you have the time / money to do them...never get done! The things you decide to jump on right away, before they get out of hand, are usually already out of hand.
#7 olcowhand OFFLINE
  • 42,460 Thanks
  • 31,824 posts
Posted August 19, 2010 - 07:35 PM
:ditto::bigrofl:
#8 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted August 19, 2010 - 09:01 PM
I've also learned not to post things on the internet after I've had a really hard day and a few to many beers! :beer::blush2:
#9 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted August 19, 2010 - 09:16 PM
:ditto::ditto::ditto:
Been there done that:beerchug:
#10 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,167 posts
Posted August 19, 2010 - 09:24 PM
I learned that reading this thread is just a gut buster.
Oh and not to let broken2 set you up on a date.:bigrofl::bigrofl::bigrofl:
#11 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted August 22, 2010 - 09:45 AM
Sears style implements dont last long behind a MAssey 1855
Its easier to bend metal than straighten (see above lesson)
looking at tractor porn will get you and your wallet in trouble with the misses
I want that tractor does not equal I can afford it
Nickle and dime parts equals dollars after awhile
Always check for an adams apple on broken2s date!
#12 MH81 OFFLINE
Posted August 24, 2010 - 08:08 PM
When you change the drive belt on a Craftsman II, make sure that you follow the "Idiot-Proof" directions. Then check yourself. Then get on the tractor, get back off & check again.
If you don't learn the above lesson, the belt keep you went over instead of under will, over time, begin to cause slippage. This slippage can be corrected temporarily by hooking your heel over the clutch pedal & pulling back while cursing.
After mowing in the above style & wondering both why the new belt is slipping & "what's that smell", remove the deck, run it up on ramps, crawl underneath & inspect the tensioner. Then look where you can put a helper spring on this money sucking piece of Craftsman. Continue to believe you are not at fault & it has to be the equipment. Put arm where it does not belong trying to follow tensioner spring.
After determining how much skin you've lost getting your arm out, let your eyes unfocus just enough to see the before-mentioned keep. Continue to lay there, bleeding & cursing yourself out.
Fix belt routing & determine if you're gonna fess up on GTTALK.
As a side note: I also learned that mowing the high stuff & then removing the deck where your wife will park will cause raking & some verbal abuse from said spouse when she tracks in the grass you left behind.
