Rebuilding a single bottom plow to be cat 0 3point
19 replies to this topic
#1 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted October 14, 2011 - 02:11 PM
Well I am done most of my other projects, so I figured I would finally re do my bottom plow. I have no idea what it is but it works pretty good.
What I have in mind is to make it dedicated to its own frame, and have the plow itself adjustable rather than tweaking arms and links and such.
Here is what I have fondled up today so far...
My next question is , how deep should plow ? Right now it can go down 8 or more inches but is this too deep for it ? Not sure , never really played much with a little plow.
  • Littledeere said thank you
#2 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted October 14, 2011 - 02:22 PM
The std guide is to plow no more deep than half the cutting width of the plow. So if that's an 8" plow....4" deep. 10" plow....5" deep....and so on.
Here's how to measure width of cut:
  • powerking56, KennyP and skyrydr2 have said thanks
#3 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted October 14, 2011 - 06:15 PM
Just tacked things together enough to try it, workday about the same, so a few more adjustments are in order, but first it needs to dry out some more. The colter seems to cut the ground nice but it needs a touch more roll to make sure the sod flops over. Also need to get the top link centered a bit better. But all in all not too bad for the first attempt. I will fool with it tomorrow and then if all is good .ill weld it out and give it a coat of paint and grease up the shar.
Thanks Dan that was great.
#4 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted October 14, 2011 - 06:47 PM
I forgot to add....super slick work on that tool bar!
#5 MH81 OFFLINE
  • 29,978 Thanks
Posted October 14, 2011 - 08:25 PM
:ditto: that's great work there.
#6 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted October 14, 2011 - 10:02 PM
Very nice work on the hitch!
#7 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted October 15, 2011 - 05:05 AM
Nice looking hitch. Hope it works out good without to much tweaking.
I haven't plowed since I was a teenager(loooong time ago), but doesn't speed have an effect on the roll over along with depth of cut?
#8 mjodrey OFFLINE
Posted October 15, 2011 - 05:18 AM
Super slick work on that tool bar!
I second the:ditto: Nice job.
#9 Littledeere OFFLINE
Littledeere
  • 1,658 Thanks
  • 1,487 posts
Posted October 15, 2011 - 09:05 AM
Thats some pretty neat work there
  • skyrydr2 said thank you
#10 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted October 15, 2011 - 06:27 PM
Well it works well, only a minor mod needed for the top link, it is so fat to the right that I want to add a 3rd plate and a angled brace. Here is a video of it working.
Modified plow to 3point hitch - YouTube
  • Alc and Littledeere have said thanks
#11 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 15, 2011 - 06:39 PM
First I have to say, very nice plow setup. Now, another unrelated question, what do you use the school bus for?
#12 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted October 15, 2011 - 06:48 PM
Looks good, Keith. Seems to be turning things over real well. Good Job!
#13 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted October 15, 2011 - 06:57 PM
That was at my brothers place, my big welder is there , the bus is used for storage, there are 2 of them , one is painted green to blend in to the woods .
  • wvbuzzmaster said thank you
#14 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted October 15, 2011 - 08:50 PM
Great build.
#15 Cvans ONLINE
  • 7,279 Thanks
  • 6,373 posts
Posted October 15, 2011 - 09:15 PM
Looks like you did a good job on the hitch. Tractor sounds good also.
