Just bought a 332
20 replies to this topic
#1 ldone OFFLINE
ldone
  • 9 posts
Posted October 12, 2011 - 10:03 PM
Bought as is, does not run, but cranks good....is getting fuel ok, sprayed wd40 in air intake but no luck........any ideas?
#2 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted October 12, 2011 - 10:15 PM
Does it have spark?
#3 ldone OFFLINE
ldone
  • 9 posts
Posted October 12, 2011 - 10:22 PM
Uh!.........help me out here........how does a diesel have spark? It does not try to start.....only cranks nicely
I know that the glo plug light works and goes off after a short period of time
#4 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted October 12, 2011 - 10:37 PM
My bad, I'm not sure what you would check on a diesel other than if it's getting fuel. Maybe compression?
#5 KennyP ONLINE
  • 40,975 Thanks
  • 47,146 posts
Posted October 13, 2011 - 04:46 AM
Welcome, Idone! I'm like Gibby, if it doesn't have spark plugs, I don't know what the heck could be wrong with it. Maybe the injector pump is out of time?
#6 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted October 13, 2011 - 08:51 AM
Any white smoke while cranking? Electric fuel pump working? Had to replace the electric fuel pump on my 330 not long after I got it home. Tons of power but wish it had a hi/low range like the 400 series.
#7 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted October 13, 2011 - 09:07 AM
Put your hand over the intake while cranking. It should suck hard on your hand. If not, then either the muffler is stopped up, or the valve timing is out of whack due to sheared timing key or the like, stuck valves, or just plain worn out rings. WD40 is not powerful used as a starting fluid (but engine safe), and if compression is very low it will not be volatile enough to fire the diesel. It takes VERY little true starter fluid in these little diesels and too much can damage the engine!
#8 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 13, 2011 - 10:17 AM
Congratulations on the new tractor. Have you checked to make sure the glow plugs are getting power. It sounds like the time delay relay is working but that doesn't guarantee they are heating.
#9 ldone OFFLINE
ldone
  • 9 posts
Posted October 13, 2011 - 11:01 AM
Thanks for the helpful replies........fuel pump is working, I "burped" the fuel filter.........intake seems to suck hard on palm of hand..........mild white smoke coming out of exhaust.......shot some ether into intake, did not make any difference........will ether work if glow plugs are not working? How do you test them?
Just discovered that the radiator is draining somewhere inside of engine.......not suppose to do that......and the breather hose is puffing when cranking
Edited by ldone, October 13, 2011 - 11:16 AM.
additional information
#10 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted October 13, 2011 - 11:17 AM
Glow plugs and either don't play well together. My glow plugs are disconnected (relay issue) so she gets a little shot of either when the engine is not at operating temp. Maybe loosen the fuel line at each injector to get any air out that may have gotten in there. You should see no bubbles.
#11 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted October 13, 2011 - 11:20 AM
Sounds like you have a blown head gasket...worst case a cracked block or head.
#12 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted October 13, 2011 - 11:23 AM
Whoops, didn't see the part that was edited in...
#13 sgtrock1976 OFFLINE
sgtrock1976
  • 6 Thanks
  • 114 posts
Posted October 13, 2011 - 12:09 PM
Keep thinking I want a diesel, but I know very little about gas engines and absolutely nothing about diesel engines. That's why this site is so important to me.
#14 ldone OFFLINE
ldone
  • 9 posts
Posted October 13, 2011 - 01:58 PM
dosen't sound good......think I will sell and let someone else fix it
#15 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 13, 2011 - 05:33 PM
Thats too bad. Before you commit to selling it consider having the engine looked at by an experienced diesel mechanic.
