Hello all, Haven't been on for awhile. A while back I had trouble with one of my ss16 twin's fuel pump. I took off the tank,stripped all of the fuel line from the tank to the firewall. Up under the seat deck where no one would go I found what I figured was another filter and couldn't figure out why they would have put one there. I replaced the fuel line and pulse type pump and now after it sets for a few days the engine won't start. No fuel. Now I am wondering if that "filter" wasn't actually a check valve to keep the fuel from running back into the tank. Does this make sense to any of you? If so can anyone tell me where I might purchase one? Thanks in advance. This is a great site with lots of helpful members.
SS16 fuel problem
Started by
iron Mike
, Oct 11, 2011 07:34 PM
7 replies to this topic
#1
OFFLINE
Posted October 11, 2011 - 07:34 PM
#2
OFFLINE
Posted October 11, 2011 - 07:40 PM
If it was a check valve, someone added it, I don't think they came with one. I read somewhere one time to use the small diameter fuel filters with the Onan engines. I don't know if there is a specific reason, or just somebodies own idea. I use regular large diameter in line fuel filters and haven't had an issue.
- iron Mike said thank you
#3
OFFLINE
Posted October 11, 2011 - 07:44 PM
I've never seen a check valve, but it sounds like a good idea. I do have 2 thoughts tho.
You could PM member BHTS and see if he has stock on them.
Or put a manual shutoff valve near the carb where you can get to it without opening the hood. Anywhere in the line should do it.
#4
OFFLINE
Posted October 11, 2011 - 08:08 PM
If you get a part number for a inline check valve I would like to try on my 318 . I was thinking on trying this , used on snowmobiles , but didn't want to dig into the tank , Al
https://www.denniski...27.prd/1827.sku
#5
OFFLINE
Posted October 11, 2011 - 08:10 PM
Im pretty sure the factory pump has a built in check valve to prevent backflow of fuel.
#6
OFFLINE
Posted October 11, 2011 - 11:21 PM
Yes it does have a check valve, better recheck how you put it back together
#7
OFFLINE
Posted October 12, 2011 - 11:40 PM
I will do that Al.
- Alc said thank you
#8
OFFLINE
Posted October 12, 2011 - 11:45 PM
I'll have to try and purchase one. I,of course,destroyed that one. Curiosity is costly some times. thanks for the info.
