New Small-Work Table
8 replies to this topic
#1 KennyP OFFLINE
  • 33,164 Thanks
  • 42,643 posts
Posted October 11, 2011 - 06:05 PM
I have had this old desk sitting out back for a while and was wondering what I could do with it. Well, yesterday I came up with a plan. Here's the desk partially dismantled:
Then you add this to the mix:
Insert the pipe into the adjustable thingy on the front and you have a swiveling, height adjustable work table that you can sit at and be comfortable. The seat even swivels.
I have been using the cast iron saw top for clamping small parts to for welding. Keeps things in alignment pretty good.
Oh yeah, the new parts in the helmet are a life saver. Got to use it to weld the bracket together for the bottom of the saw table. "I can see clearly now".
Enjoy!
#2 Alc ONLINE
  • 6,125 Thanks
  • 7,027 posts
Posted October 11, 2011 - 06:55 PM
The cast iron saw tops are usually surface ground and should be very flat , I've used mine ( still works as a saw ) for a surface plate , laying a piece of sandpaper on it to true up a Kohler head , water pump outlet ect. it comes in handy , Al
#3 mjodrey OFFLINE
Posted October 11, 2011 - 07:02 PM
Kenny,you just full of surprises,and new projects too.Keep 'em comin'.
#4 KennyP OFFLINE
  • 33,164 Thanks
  • 42,643 posts
Posted October 11, 2011 - 07:06 PM
Al, this came off a very old Sears. The shaft was messed up badly where the pulley was run loose. I still have the rest of the parts for it. I even found a manual for it. It was a 103.24241, 8" saw.
#5 KennyP OFFLINE
  • 33,164 Thanks
  • 42,643 posts
Posted October 11, 2011 - 07:14 PM
I got the tractor port in order, so it was time to start doing some things I have thought about for a while. The dump trailer will take some time though.
#6 JDBrian OFFLINE
  • 9,595 Thanks
Posted October 11, 2011 - 07:21 PM
Thats a useful little project, Kenny. I have a cast iron Sears 10" saw from about 1985. I think it will outlast me. Thats a good application for one of those tops. Al, I used my saw top this summer to flatten a K321 head.
#7 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted October 11, 2011 - 08:34 PM
Nice work. I like that you were able to make something helpful out of old stuff. I try and do that whenever possible. Thanks for the great idea!
#8 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted October 25, 2011 - 06:30 PM
:bounce:Oh boy Oh boy I have one of those cast Iron saw tops myself. Now I know what I'm going to do with it. Maybe not a desk but I have a couple of old metal pedestal tables that are not doing anything worth while. So another project.
I just love it when folks come up with ideas that I should have thought of. Kind of saves me all the brain energy.:D
#9 KennyP OFFLINE
  • 33,164 Thanks
  • 42,643 posts
Posted October 26, 2011 - 05:28 PM
Don, what I like is that I can spin the top 360 degrees, sit down and be comfortable with what ever I use it for. I haven't really used it yet, but the time will come. The whole thing is heavy enough I don't have to worry about tipping. And I can still take the top off, remove 4 bolts, and use it elsewhere when needed. Plenty of room to clamp something down if needed.
