Drain plug
7 replies to this topic
#1 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted October 10, 2011 - 03:43 PM
The blow-up for a 5053 trans shows a drain plug on the bottom of trans. I don't see this plug on mine. Is it under the hitch?
#2 GWest OFFLINE
GWest
  • 555 Thanks
  • 507 posts
Posted October 10, 2011 - 06:32 PM
Sitting in the seat the plug is in the left rear corner. It is an Allen socket head 1/4" NPT and the hole is likely full of dirt. Dig it out and tap the Allen wrench to make sure it is well seated. You don't want the wrench to slip and ruin the hex socket. Use a thread sealer when reinstalling.
Garry
  • 70Blazer said thank you
#3 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted October 15, 2011 - 05:28 PM
Garry
Looks like the PO already stripped the 1/4 Allen plug out. Now to figure out how to remove it.:wallbanging:
#4 olcowhand ONLINE
  • 42,897 Thanks
  • 31,941 posts
Posted October 15, 2011 - 05:33 PM
On stripped allen plugs/bolts, I've taken a hand impact wrench, then taken the next size larger allen bit & ground the ends slightly tapered smaller on the end. Drive this into the plug, then slip on the hand impact tool, hit with a hammer & almost always turns them out. The hand impact tool does 3 things....the hammer sets the taper deeper & tighter while at the same time turning it outwards. The shock of hitting it with the hammer also jars the threads free. You lose a perfectly fine impact bit, but gain another useful special purpose bit for the next time this comes up. Bits are cheap anyway though.
  • dstaggs, MH81, 70Blazer and 1 other said thanks
#5 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted October 15, 2011 - 09:49 PM
Sounds like a plan olcowhand. I may need to go to my buddies shop since I seem to always be tool deficient:)
#6 WH1056 OFFLINE
WH1056
  • 64 Thanks
  • 59 posts
Posted October 17, 2011 - 06:36 PM
I have had really good luck with tapping a Torx bit into the stripped plug. Don't get wild with the hammer though - the bottom of the case isn't overly thick.
#7 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted October 23, 2011 - 05:15 PM
Well finally I got that sob plug out. None of the above tricks worked so I had to drill through it and use easy out. I flushed it to make sure no shavings were present. New plug good to go. Oh, not to forget what a pain it was to remove the big pin for the slot and tow hitch. I cleaned that up with Emory cloth, got some anti sieze on it. Done.:bounce:
#8 MikesRJ OFFLINE
MikesRJ
    One of the 1st 500!
  • 71 Thanks
  • 118 posts
Posted October 24, 2011 - 03:52 PM
Good job!
