1st david bradley
11 replies to this topic
#1 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted October 09, 2011 - 08:06 AM
Hope thease pictures went through,if so can any one tell me anything about it.
#2 Bolens 1000 OFFLINE
  • 15,425 Thanks
  • 18,280 posts
Posted October 09, 2011 - 07:28 PM
Nice looking David Bradley
There are a few guys here that have some of these machines and should be able to answer your questions
Edited by Bolens 1000, October 09, 2011 - 07:58 PM.
  • tractorman604 said thank you
#3 Alc OFFLINE
  • 7,226 Thanks
  • 7,578 posts
Posted October 09, 2011 - 07:43 PM
Can't tell you anything about it except I wish it was mine !! Looks like it was really taken care of , Al
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted October 10, 2011 - 06:19 AM
David Bradley Tractor :Company History - YouTube
David Bradley tractors and implements
Here is something to get you started,
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted October 10, 2011 - 06:28 AM
That is a nice find, i would leave it as it is so much of the original paint is in good shape, the muffler is not original but a New old stock tube muffler can be had, i found 2 in a tiny general store yesterday,
#6 mjodrey OFFLINE
Posted October 10, 2011 - 06:42 AM
That is a nice looking DB,congrats.
#7 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 10, 2011 - 03:27 PM
Great original condition David Bradley. If it works and you're happy with it, I wouldn't change a thing, not even the muffler. But please, put a shroud on that engine.
#8 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted October 10, 2011 - 04:09 PM
I just have the shroud off so i can pull the flywheel,and when i did the flywheel had a little crack about 3/4 of an inch beside the magnet.Could that cause a no spark issue? also the key looked a tad worn and a very slight bend
#9 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted October 11, 2011 - 06:11 PM
More then likely yes, sounds like another flywheel is in order, magnet could come out and hit the armature and snap it off along with the coil, speaking of coils looks like that one is new,
#10 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted October 11, 2011 - 07:16 PM
Yes, that is a new coil points and condensor,they were changed thinking that was the problem but i am pretty sure i have to hunt down a flywheel.I still have the original ones though.
#11 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted October 11, 2011 - 08:15 PM
that's good, hang on to them, those coils are better then what the bigger models got such as the 14 or 19, while your at it, check for play in the crank and connecting rod, a crack in the flywheel is not good for the engine internally, have you cleaned the carb ?,
those old model 6 are built to last,
#12 Littledeere OFFLINE
Littledeere
  • 1,658 Thanks
  • 1,487 posts
Posted October 16, 2011 - 09:20 PM
Neat old tractors lots and lots of attachments made for them
