got the kubota engine
35 replies to this topic
#16 Boss 448 OFFLINE
Boss 448
  • 48 Thanks
  • 248 posts
Posted October 09, 2011 - 05:46 PM
make sure you get good penetration
I'm sorry - I was napping there for a while. We're still talking about welding here, right? :bigrofl:
#17 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 09, 2011 - 06:08 PM
al;right, will do. my task of the day was clean up the yard and get a plate to put over where the hydro pump is on the kubolen's engine. well i got the stainless steel to cut into a plate but i never made it. also tonight im going to free my stub shaft of the 3 belt pulley that ran my pto and start making plans for the stubshaft on the engine to the driveshaft
#18 mjodrey OFFLINE
I would hope I was.:bigrofl:
#19 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 09, 2011 - 08:10 PM
the freaking pulley on the stub shaft im gonna use is pissing me off. ive drilled the hex nut bolts out, torched it up and down, 50 times, and now sprayed it with lube and awesome to clean the crap out between the inside of the pulley and the shaft. im gonna scream soon.
#20 Cvans OFFLINE
  • 7,462 Thanks
  • 6,468 posts
Posted October 09, 2011 - 09:00 PM
How do you plan to cut the Stainless steel? Why did you choose stainless for this. Torch is out of the question. Cutoff wheel for square plate. Hole saw and cutting fluid for round. If you have access to a plasma cutter you can use that for both.
Be careful with the heat near the crankshaft. You can cause yourself all kinds of grief if your not cautious.
#21 Boss 448 OFFLINE
Boss 448
  • 48 Thanks
  • 248 posts
Posted October 10, 2011 - 09:19 AM
I'm not an expert in this area but my limited understanding of stainless steel is that it can be very difficult to machine and/or weld which I would think would make it undesirable for this type of application. Please correct me if I'm missing something here but would not mild steel actually work better in this situation?
JN
#22 Cvans ONLINE
  • 7,462 Thanks
  • 6,468 posts
Posted October 10, 2011 - 10:17 AM
Boss is correct. Cutting, drilling, and welding Stainless can be very frustrating for the novice. It is much more prone to warping during the welding process.
Yours was very good advise.
Edited by Cvans, October 11, 2011 - 09:59 AM.
#23 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 10, 2011 - 03:04 PM
i thought my post went through but i guess it didnt. the only thing im using the stainless for is the plate im making to go over where im taking the hydro pump off of so it doesnt burn out with no fluid. it was free and it will work. everything else will be made with plain old steel.
#24 Boss 448 OFFLINE
Boss 448
  • 48 Thanks
  • 248 posts
Posted October 11, 2011 - 08:45 AM
OK - I think that makes more sense. The way it sounded to me I thought you were about to really create some difficult work for yourself. No point fighting battles you don't have to.
JN
#25 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 11, 2011 - 02:39 PM
the stainless worked just fine for the plate i made to cover the hole. i used a jigsaw to cut it, it was 1/8th inch, and i used a wood blade. worked great.
#26 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 11, 2011 - 04:54 PM
so i went to start it, mind you there 2 things broken that connect to the starter, but it still started for me when the guy did it. and all the starter does is spin, it doesnt even spin the flywheel. any ideas? it worked fine a few days ago.
#27 olcowhand ONLINE
  • 43,149 Thanks
  • 32,005 posts
Posted October 11, 2011 - 04:55 PM
Polarity reversed on battery terminals?
#28 mjodrey OFFLINE
Posted October 11, 2011 - 05:11 PM
The bendix not kicking out to the flywheel?
#29 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 11, 2011 - 06:14 PM
nope the polarity is right and i dont think the bendix is kicking out? is that a cheap issue to fix?
#30 Cvans OFFLINE
  • 7,462 Thanks
  • 6,468 posts
Posted October 11, 2011 - 07:35 PM
Pull the starter and have it checked at an auto parts store. That will determine if the starter is your problem.
