got the kubota engine
35 replies to this topic
#1 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 08, 2011 - 06:37 PM
so i traded a g14 a cab a snowblower and a deck for my kubota engine. it needs a 32 dollar solenoid since he broke it loading it into his truck( the wire goin from the battery to the solenoid got stuck in his tailgate and when he yanked it he broke the solenoid) but he was still able to run it, some black smoke on startup but then it ran nice. no stubshaft on the flywheel end but a 6 bolt pattern with the bolts. so i think this engine is going to fit in with a little bit of light fabrication. also the engine must weigh a few hundred pounds easily, me and the 5x5 italian guy who sold it to me could barely move it. i think the front axle of the ht20 is going to hold the weight effortlessly though.
#2 Cvans OFFLINE
  • 7,283 Thanks
  • 6,376 posts
Posted October 08, 2011 - 09:56 PM
I hope you will keep us posted as you make progress on this project. Photos are always a plus.
Good luck.
#3 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 08, 2011 - 10:23 PM
ill take some pics tomorrow, im so tired i dont even think i can crawl over to my bed, i might have to sleep on the floor. but i made progress, i got my stub shaft im using off my kohler, tomorrow i gotta work on it asap. if i hurry i might get her going tomorrow.
#4 mjodrey OFFLINE
Posted October 09, 2011 - 04:52 AM
This should be an interesting conversion,and I'll be watching it closely.
#5 caseguy OFFLINE
  • 1,629 Thanks
Posted October 09, 2011 - 09:55 AM
Congrats on the new acquisition J! Can't wait to see some pics!
#6 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted October 09, 2011 - 09:57 AM
Good luck.
Pics are a REQUIREMENT!
#7 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 09, 2011 - 12:26 PM
ahh ok ok ill go get pics, my problem is how to get the engine out of the truck without a hoist.
#8 KennyP OFFLINE
  • 40,881 Thanks
  • 47,093 posts
Posted October 09, 2011 - 12:50 PM
Back up real fast and hit the brakes.:bigrofl::bigrofl:
Or, tie the engine to a tree and drive forward.:bigrofl::bigrofl::bigrofl:
Or, tie the engine to a tree limb and drive out from under it.:bigrofl::bigrofl::bigrofl::bigrofl:
#9 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 09, 2011 - 02:00 PM
well it rolled off the truck, i had a good setup which was putting it on the hand truck rated for 900lbs. and rolling it down my loading ramps, well the one ramp started to shift and the engine rolled down into the mud unharmed. the only thing that broke was a plastic plug that went into the alternator. so mission success.
#10 MH81 OFFLINE
  • 29,978 Thanks
Posted October 09, 2011 - 02:17 PM
Glad there wasn't more damage done.
Now to pick it up again... LOL
#11 KennyP OFFLINE
  • 40,881 Thanks
  • 47,093 posts
Posted October 09, 2011 - 03:17 PM
Glad it's at ground level now. Sorry to hear of the mishap, though. Things that heavy, I load on my trailer. It's low to the ground. Not so far for things to fall off it.
#12 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 09, 2011 - 03:31 PM
stub shaft.jpg ok so i think i planned out my stub shaft. in gonna get lets say a 3 inch circle of steel, lets say 3/8th inch thick. get the holes drilled into it in the pattern of the kubotas flywheel. then i get lets say a 2 inch dia. pice of steel tubing 2 inches long. get a plate made for the stub shaft im using. then ill get it welded together on center and drop the engine in. heres a thing i made on paint, kinda represents my ideas for the plates, im not a paint expert though. also i plan to drill the holes proportional, like i cant do on paint.
#13 KennyP ONLINE
  • 40,881 Thanks
  • 47,093 posts
Posted October 09, 2011 - 03:50 PM
Sounds like a plan. Good luck with it.
#14 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 09, 2011 - 04:08 PM
i guess mig welds will hold it? or should i get it tig welded?
#15 mjodrey OFFLINE
Posted October 09, 2011 - 04:38 PM
You will have no problems with the mig welds not holdin , their welds are very strong. That being said,make sure you get good penetration.
