Kohler kt 17 series II trouble
2 replies to this topic
#1 Brock OFFLINE
Brock
  • 2 Thanks
  • 9 posts
Posted October 08, 2011 - 05:24 PM
Ok so today got back to messin with the cub 782 that has the series two kohler kt. Anyways the engine is relatively new purchased and installed brand new a few yrs back then sat ever since. I am trying to get it goin and it starts up and runs but I think its only running on one cylinder. The plug and coil are working on that side,right, but its blowing fuel up out of the carb bad. Does that mean its a stuck valve? Someone please help and w e it is can someone tell me how to fix it. Thanl you.
#2 olcowhand ONLINE
  • 43,182 Thanks
  • 32,014 posts
Posted October 08, 2011 - 06:56 PM
yes, sounds like either a sticky valve, or maybe old carbon broke loose & is holding the intake valve open. Do a compression check to be sure. You can do a simple check without special tools.....just take out the spark plug & see if it will pop your finger off the plug hole while spinning the engine. Be sure to keep the plug wire away from you to avoid a shock, or better yet, ground the kill wire. If you can hold your finger over the hole with no problem, then a valve is stuck open almost for sure.
#3 Brock OFFLINE
Brock
  • 2 Thanks
  • 9 posts
Posted October 08, 2011 - 08:35 PM
Ok I believe that is it because compression seems low. So now what? Reseat valve orwhat ? Thank you very much olcowhand.
